sent some to the group but they didn't appear re court airline
used rich text format to get the photos on any ideas pls Mike |
"flybywire" wrote in message ... sent some to the group but they didn't appear re court airline used rich text format to get the photos on any ideas pls Mike Hi Mike, Unfortunately rich text is not a format for use in a newsgroup. Posts to newsgroups should be made in plain text. Photographs should be attached to the message as files of jpeg's and for preference the file size should be kept fairly small so that more people can see it more easily. I use a freeware program called Irfanview to resize and slightly compress the files so that they are about the 100-300k size (for me about 800 pixel wide and around 90 percent on the quality slider). If you check the attachment (paperclip) on the top right of this post you will see a file named DSC_09480001.jpg which is the picture showing (hopefully) below. Hope this helps. -- Andrew B (Cheshire, England) "Heavier-than-air flying machines are impossible." (Lord Kelvin, president Royal Society, 1895.) |
Thanks Andrew
When i used to use outlook express all was well with plain text and adding photos for some reason i cant do it with windows mail thats [progress for you cheers Mike "Andrew B" wrote in message om... "flybywire" wrote in message ... sent some to the group but they didn't appear re court airline used rich text format to get the photos on any ideas pls Mike Hi Mike, Unfortunately rich text is not a format for use in a newsgroup. Posts to newsgroups should be made in plain text. Photographs should be attached to the message as files of jpeg's and for preference the file size should be kept fairly small so that more people can see it more easily. I use a freeware program called Irfanview to resize and slightly compress the files so that they are about the 100-300k size (for me about 800 pixel wide and around 90 percent on the quality slider). If you check the attachment (paperclip) on the top right of this post you will see a file named DSC_09480001.jpg which is the picture showing (hopefully) below. Hope this helps. -- Andrew B (Cheshire, England) "Heavier-than-air flying machines are impossible." (Lord Kelvin, president Royal Society, 1895.) |
ah silly me it has to be an affached file !
"flybywire" wrote in message ... Thanks Andrew When i used to use outlook express all was well with plain text and adding photos for some reason i cant do it with windows mail thats [progress for you cheers Mike "Andrew B" wrote in message om... "flybywire" wrote in message ... sent some to the group but they didn't appear re court airline used rich text format to get the photos on any ideas pls Mike Hi Mike, Unfortunately rich text is not a format for use in a newsgroup. Posts to newsgroups should be made in plain text. Photographs should be attached to the message as files of jpeg's and for preference the file size should be kept fairly small so that more people can see it more easily. I use a freeware program called Irfanview to resize and slightly compress the files so that they are about the 100-300k size (for me about 800 pixel wide and around 90 percent on the quality slider). If you check the attachment (paperclip) on the top right of this post you will see a file named DSC_09480001.jpg which is the picture showing (hopefully) below. Hope this helps. -- Andrew B (Cheshire, England) "Heavier-than-air flying machines are impossible." (Lord Kelvin, president Royal Society, 1895.) |
| Thread Tools | |
| Display Modes | |
| More photos | Maple1 | Aviation Photos | 2 | October 30th 08 10:30 PM |
| HMS Warrior - 1950s Flightdeck Photos [7 photos, 'bout 350kb) | Andrew[_5_] | Aviation Photos | 13 | August 13th 08 05:36 PM |
| 300 photos | Maple1 | Aviation Photos | 0 | June 13th 07 06:05 AM |
| ~ PHOTOS FROM THE FALLUJAH MASSACRE [won't find *these* photos on | TekTeam26 | Military Aviation | 0 | April 12th 04 02:49 AM |
| C-150 for photos? | Simone Canosa | Piloting | 17 | December 6th 03 02:49 AM |
