Need help! Magnetic Compass Errors!
Old January 1st 09, 06:18 PM posted to rec.aviation.piloting
Default Need help! Magnetic Compass Errors!
On Jan 1, 9:46*am, Stefan wrote:
Karl-Heinz Künzel schrieb:
http://en.wikipedia.org/wiki/Aircraft_compass_turns
Did you read this article? It explains exactly nothing.
A better one:
http://pilotsweb.com/navigate/compass.htm
And a better layout of the magnetic lines of force that cause compass
errors:
http://www.geology.ohio-state.edu/~v.../xfig25_14.jpg
Because the lines of force are not parallel to the earth's surface
except near the equator, anytime we tip a magnetic compass's card its
magnet will want to point downward toward the earth's core. If its
level it's pretty accurate. So in turns or during acceleration or
deceleration, the card tips and the magnet points elsewhere than where
we'd like it.
Dan
Old January 1st 09, 06:22 PM posted to rec.aviation.piloting
* A better one:http://pilotsweb.com/navigate/compass.htm
errors:http://www.geology.ohio-state.edu/~v...xfig25_14..jpg
we'd like it.
* * * * *Dan
I should have added that at high latitudes, where the dip is
severe, the compass is not accurate and isn't used. In northern Canada
we have the Area of Compass Unreliability; see
http://gsc.nrcan.gc.ca/geomag/field/compass_e.php
In this area pilots may use the sun's true bearing tables, which give
a direction based on an accurate time. Of course, most rely on GPS...
Dan
Dallas-Fort Worth TRACON Management Routinely Misclassified Operational Errors and Deviations as Pilot Errors Larry Dighera Piloting 56 May 6th 08 01:17 AM
DFW ATC identifying Operational Errors As Pilot Errors? Larry Dighera Piloting 8 July 18th 07 10:49 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 03:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
