paul kgyy wrote:
On Jan 27, 2:50 pm, " wrote: Is there any software out there that will add the Com frequencies to the Nav log instead of having to look them up on the low route maps? thanks Jepp's flightstar lists the comm freqs in the nav log for airports in your flight plan, but not ATC freqs. You do have to keep the data current, which I do annually - runs about $75 iirc. What's the difference between a com and ATC frequency? |
On Jan 28, 4:53*am, Sam Spade wrote:
paul kgyy wrote: On Jan 27, 2:50 pm, " wrote: Is there any software out there that will add the Com frequencies to the Nav log instead of having to look them up on the low route maps? thanks Jepp's flightstar lists the comm freqs in the nav log for airports in your flight plan, but not ATC freqs. *You do have to keep the data current, which I do annually - runs about $75 iirc. What's the difference between a com and ATC frequency? Probably not a good use of the term - what I meant is that FS will not list Center frequencies for IFR communications. Those appear primarily on the Low Altitude Enroute charts. It does list approach and departure freqs. |
On Wed, 28 Jan 2009 13:26:28 -0800 (PST), paul kgyy
wrote: On Jan 28, 4:53*am, Sam Spade wrote: paul kgyy wrote: On Jan 27, 2:50 pm, " wrote: Is there any software out there that will add the Com frequencies to the Nav log instead of having to look them up on the low route maps? thanks Jepp's flightstar lists the comm freqs in the nav log for airports in your flight plan, but not ATC freqs. *You do have to keep the data current, which I do annually - runs about $75 iirc. What's the difference between a com and ATC frequency? Probably not a good use of the term - what I meant is that FS will not list Center frequencies for IFR communications. Those appear primarily on the Low Altitude Enroute charts. It does list approach and departure freqs. it doesn't list departure/approach either. Basically it only shows the frequencies for the airports, nothing enroute. |
On Jan 28, 7:18*pm, Peter Clark
wrote: On Wed, 28 Jan 2009 13:26:28 -0800 (PST), paul kgyy it doesn't list departure/approach either. *Basically it only shows the frequencies for the airports, nothing enroute. Mine does list approach and departure freqs - maybe because I have the IFR version. |
$10 Flight Planning Software | [email protected] | General Aviation | 0 | February 15th 07 06:56 PM |
Best Flight Planning Software for a jet? | CaptainCraig | Piloting | 2 | September 8th 06 02:50 AM |
Flight planning software | GE | Piloting | 13 | April 12th 06 05:01 AM |
Flight Planning Software | Chris G. | Piloting | 22 | July 4th 05 06:33 PM |
what flight planning software do you use? | Sridhar Rajagopal | Piloting | 52 | October 3rd 03 07:39 AM |
