For Nimbus 3T & 4T see TN 825-44/831-12/863-17/868-16 (a single TN but the
numbers indicate different gliders to which it applies) This allows transponder antenna on upper fusalage. There is a different TN for Nimbus & Duo with antenna on underside of fusalage. At 03:31 19 February 2009, Darryl Ramm wrote: On Feb 18, 7:06=A0pm, wrote: Looking for some suggestions on location of Transponder antenna from people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K Is there a reason why you don't follow the factory TN showing a location and correct mounting/groundplane installation. Darryl |
Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 06:03 PM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Nav Antenna Placement | Jim Pensinger | Home Built | 7 | October 4th 04 09:55 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
