On Apr 19, 1:51*pm, wrote:
When I push hard forward to increase airspeed.....the cambridge VSI goes up to 10knots positive. Then when I pull back to bleed off airspeed.....the VSI goes down to 10 knots negative. To answer you question directly - I don't believe you can fix the problem you describe with electronic compensation. Here's why: If I remember correctly an uncompensated vario reads climb when you bleed off airspeed and sink when you accelerate. This is because with static pressure only as the pressure source (no compensation) your vario will indicate the altitude change irrespective of any associated change in kinetic energy. Your description reads like the opposite, or OVER-compensation. I believe there also is an effect from the initial drag of adding lift in a pullup (and presumably the opposite from reducing lift in a push- over maneuver). That causes the uncompensated vario to show some small altitude loss at the very beginning of a hard pullup (think of the glider "mushing" a bit when you pull hard). This means that on a hard pullup the vario would read momentarily down by 1 knot or so, then read up until the speed stabilizes - all in still air, of course. Putting this second effect aside for now, a pullup from 100 knots down to 60 knots will gain you about 250 feet in about 10 seconds - depending on the steepness of the pullup. That translates to 15 knots average climb rate. You will see more climb rate early in the pullup than at the end. If you were reporting 10 knots of positive climb rate on a pullup then it would lead me to believe that you are getting little or no total energy compensation and you should set the CAI 302 to 70% or so. This has two problems: First, you are reporting behavior that indicates 70%+ OVER-compensation, not under. Second, I'd be hard- pressed to recommend to someone that they put that much electronic compensation on top of a TE probe since you are likely masking a big problem. Finally, you are asking for a specific answer to an insufficiently defined problem. Without knowing the pullup profile the fact that you are showing 10 knots on the vario doesn't really give enough information to know how to set your instrument. I generated an answer by assuming a profile - but I don't really know what kind of pullup you used to generate this result. The glider matters too, but my analysis ignores this detail in favor a of a simple energy conversion relationship. Hope that's helpful. 9B |
On Apr 20, 9:09*am, wrote:
On Apr 19, 1:51*pm, wrote: I generated an answer by assuming a profile - but I don't really know what kind of pullup you used to generate this result. The glider matters too, but my analysis ignores this detail in favor a of a simple energy conversion relationship. Oh, and I generated an answer also based on the assumption that your vario is behaving in a manner opposite to what you described - unless I missed something in college physics. 9B |
| Thread Tools | |
| Display Modes | |
| WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 06:31 PM |
| Cambridge 302 & PDA -- Value of adding Cambridge 303? | V1 | Soaring | 5 | July 31st 07 04:51 AM |
| Cambridge 302A/303/SNav question | Bob | Soaring | 7 | November 26th 06 04:46 PM |
| Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 03:43 PM |
| Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 6th 04 12:22 AM |
