Mike, was the oil filter adapter also changed or was its vernatherm seat
ground when the vernatherm was changed? If the new vernatherm doesn't fit the seat in the oil filter adapter, the vernatherm fix would not be complete. When my vernatherm was changed and the seat ground, it fixed a hot oil problem in my Archer. -- Best Regards, Mike. http://flickr.com/photos/mikenoel/ "Mike Spera" wrote in message m... I have owned this Cherokee 140 since 1994. I have logged over 1000 hours in it through the original and the now installed overhauled engine. Oil temps were usually at 180 degrees (both engines)when OATs were between 50-80 degrees or so. It would read 1 needle mark higher when it got to be 95+ outside. In the last 150 hours or so, it has been drifting up and is now reading about 2 needle marks above 180 degrees (200 degrees or so?). I replaced the oil cooler because of age. It was cheaper to replace it with a new PMA'd unit than to have it checked/cleaned. I swapped the Vernatherm. No difference. Do the gauges/senders drift off with age. I am going to test the sender/gauge with hot water and a thermometer. Once it gets to that mark, it seems to stabilize. Baffles are all in good shape. What else causes temps to drift high? I know that shifting main bearings can cause this, but I doubt the engine would continue to operate for this long if this were the case. I do wonder though because the cold oil pressure is right at redline on takeoff. After 5 minutes it goes back down into the middle of the green. Thoughts/theories? Thanks, Mike |
C182 Oil Temp | Steve Leonard | Soaring | 1 | October 8th 07 10:33 PM |
carburator temp sensor | Philippe Vessaire | Home Built | 0 | May 14th 06 04:35 PM |
Cessna 172 Oil Temp | Darrel Toepfer | Owning | 10 | June 26th 05 04:04 PM |
c-182 carb temp gauge | R.T. | Owning | 1 | November 23rd 04 10:48 PM |
carb temp probe | Philippe Vessaire | Home Built | 1 | September 20th 03 08:21 AM |
