Don't put more than 10 quarts in it. More oil, nose
high attitude, the oil gets hotter as it gets thrown up into the back cylinders by the crank. You will also probably notice a lot of oil on the belly, too. Check the oil level with the nose strut compressed, and keep it between 9 and 10. If you go much below 8, you don't have enough oil to do the job and keep it cool. There are other things that can be limiting oil flow through your existing cooler making it seem like your cooler isn't working. Heard of a vernitherm? I think that is what it is called. Basically, an oil system thermostat. Maybe yours is sticking or restricting flow? I would check out what you have and what you are doing before you go trying to change the system. Also, an oil filter with an air duct out the back of the cooling baffle can further aid cooling the oil. Just a few thoughts. Steve Leonard |
On Oct 7, 2:55 pm, Steve Leonard
wrote: Don't put more than 10 quarts in it. More oil, nose high attitude, the oil gets hotter as it gets thrown up into the back cylinders by the crank. You will also probably notice a lot of oil on the belly, too. Check the oil level with the nose strut compressed, and keep it between 9 and 10. If you go much below 8, you don't have enough oil to do the job and keep it cool. The volume of oil in the case isn't important in oil cooling, it's the oil flow through and air flow across the oil cooler that are. The minimum oil level is, by FAR, 1/2 the max on the dipstick: the FARs require that an aircraft oil system function properly in all normal attitudes with 1/2 the nominal capacity in the crankcase. So if the case holds 10 qt, we need 5 for lubrication. We should take off with an amount over that sufficient to maintain this minimum for the duration of the expected flight, based on the usual rate of use. Many aircraft vomit oil out the breather pipe if filled to nominal crankcase capacity. |
| Thread Tools | |
| Display Modes | |
| C182 questions | Frank Whiteley | Soaring | 5 | October 8th 07 11:54 PM |
| C182 overhaul | Chris | Owning | 7 | September 9th 06 06:58 AM |
| Cessna 172 Oil Temp | Darrel Toepfer | Owning | 10 | June 26th 05 05:04 PM |
| C182 Car Sticker on eBay | Tom432 | Owning | 0 | February 18th 05 10:25 PM |
| Nearly new C182 checklist | Brinks | Owning | 7 | December 18th 04 05:00 AM |
