C182 questions
Old October 7th 07, 06:46 PM posted to rec.aviation.soaring
Frank Whiteley
Default C182 questions
1959 C-182 tow plane, hook's installed
Does someone have specific STC or other info concerning larger or
second oil cooler?
Does someone have a sample 337 regarding installation of external
mirrors?
TIA,
Frank Whiteley
Old October 7th 07, 07:06 PM posted to rec.aviation.soaring
BT
Frank, check with Cindy at Caracole Soaring?
Bill
"Frank Whiteley" wrote in message
second oil cooler?
mirrors?
TIA,
Frank Whiteley
Old October 7th 07, 07:24 PM posted to rec.aviation.soaring
Frank Whiteley
Bill
second oil cooler?
mirrors?
TIA,
Frank Whiteley
I will.
Frank
Old October 8th 07, 06:54 PM posted to rec.aviation.soaring
Bill
second oil cooler?
mirrors?
TIA,
Frank Whiteley
I will.
Frank- Hide quoted text -
- Show quoted text -
may want to check with Burt Compton about the mirrors. Hes got strut
mounted mirror on his 180/150.
Old October 8th 07, 11:48 PM posted to rec.aviation.soaring
john
second oil cooler?
mirrors?
TIA,
Frank Whiteley
Frank, I have installed the larger non congealing oil coolers on 0
and IO 470s , it takes the base and the cooler, and and because they
are larger, it takes some inlet work to use the larger cooler. I have
also added to the size of the cooling lip to draw more air thru it on
several planes. The non congeiling cooler was sold by contenental as
a upgrade kit for various engines, and came standard on others. Its
been quite a while since I did one, but I remember it took very little
work. a couple of shorter studs maybe? , it is mostly for very cold
weather , but it also lowers the summer temps. They are not a lot
bigger, but they do help. I also looked at the RAM baffel kit, and
copied it, It also helped as it seals better. The 182 installation is
kinda loose, mosty I think because in normal operations they are not a
cooling problem. Are the cowl flaps set to go full open and a little
more? John Barron
Old October 8th 07, 11:54 PM posted to rec.aviation.soaring
john
second oil cooler?
mirrors?
TIA,
Frank Whiteley
more? John Barron
Now I see, a 59 model, no cowl flaps right, try the bigger outlet lip
if you haven't yet. I added 3 inches. jb
C182 tow hook arrangement? [email protected] Soaring 3 November 18th 06 04:18 AM
C182 overhaul Chris Owning 7 September 9th 06 06:58 AM
C182 / SMA Jet Fuel Engine? Mike Owning 20 October 25th 05 09:33 PM
Nearly new C182 checklist Brinks Owning 7 December 18th 04 05:00 AM
C182 - Intermittent Alternator WinstonCup Owning 9 November 12th 04 01:22 AM
