Optimum CG Range
Old December 13th 09, 07:44 PM posted to rec.aviation.soaring
Brian Whatcott
Default Optimum CG Range
JJ Sinclair wrote:
CofG may be stated as a distance aft of a given reference station
which may be at (or in front of) the nose
OR
A percentage of MAC behind the wing LE
OR
A distance behind the Wing LE
The middle definition is probably the most fundamental, because there
is a known range of allowable CofG's in terms of %MAC which is
similar across a wide range of airframes
Brian W
Errrrr, not neccessarily so; The wing leading edge will be the zero
MAC point only if the leading edge of the wing is a straight line
JJ
Quite so, leading to the slightly strained specification of definition #2:
A percentage of MAC behind the wing MEAN LE station
What the devil is a mean leading edge? :-)
Brian W
Need a little more range for your 304S jet? Marc Ramsey[_2_] Soaring 1 July 22nd 07 02:39 PM
VOR volume range kevmor Instrument Flight Rules 7 February 7th 07 11:46 PM
Long range Wx Paul kgyy Piloting 4 December 31st 04 05:25 PM
What is the range of the B-1B? user Military Aviation 10 December 24th 03 05:15 AM
Fuel Range Toks Desalu Home Built 2 November 14th 03 01:51 PM
