On Jan 17, 3:08*pm, Tuno wrote:
You said "on top in 2 minutes" and I didn't know what you meant until I saw the video. On the wire for two minutes! WOW!!! I'd like to know the details -- length and type of cable? Brand of winch? Altitude gained? Makes our winch at the Prescott club look woefully inadequate! 2no Prescott does very well, IMVHO. Well, no details yet except that it looks like they got to 1450m. On top meant VFR above the clouds, naturally;^) Puts the whee! in Weedle though. More info on the website http://www.kac.be/StandardPage.aspx?RID=214 |
On Jan 17, 3:20*pm, Frank Whiteley wrote:
On Jan 17, 3:08*pm, Tuno wrote: You said "on top in 2 minutes" and I didn't know what you meant until I saw the video. On the wire for two minutes! WOW!!! I'd like to know the details -- length and type of cable? Brand of winch? Altitude gained? Makes our winch at the Prescott club look woefully inadequate! 2no Prescott does very well, IMVHO. Well, no details yet except that it looks like they got to 1450m. *On top meant VFR above the clouds, naturally;^) Puts the whee! in Weedle though. More info on the websitehttp://www.kac.be/StandardPage.aspx?RID=214 Looks like about 3030 meters of 5 mm Dyneema. Can't tell details on the type of winch used or size of the engine. A nearly 50% height to length ratio is very good. |
On Jan 17, 4:16*pm, Tim Taylor wrote:
On Jan 17, 3:20*pm, Frank Whiteley wrote: On Jan 17, 3:08*pm, Tuno wrote: You said "on top in 2 minutes" and I didn't know what you meant until I saw the video. On the wire for two minutes! WOW!!! I'd like to know the details -- length and type of cable? Brand of winch? Altitude gained? Makes our winch at the Prescott club look woefully inadequate! 2no Prescott does very well, IMVHO. Well, no details yet except that it looks like they got to 1450m. *On top meant VFR above the clouds, naturally;^) Puts the whee! in Weedle though. More info on the websitehttp://www.kac.be/StandardPage.aspx?RID=214 Looks like about 3030 meters of 5 mm Dyneema. *Can't tell details on the type of winch used or size of the engine. A nearly 50% height to length ratio is very good. It isn't possible to use 3000 meters of steel cable - it weighs too much. Dyneema makes all the difference. It'a opening up a new chapter in winch launch. The MEL "Leopard" is a winch specifically designed to use Dyneema "plastic rope". It's an excellent design. However, 1450 Meters is not particularly good. Other launches have gone as high as 1700 meters. They could have gone higher but there were airspace limitations in effect at 1700 meters. |
Winch Launch Fatality | Nyal Williams[_2_] | Soaring | 89 | June 27th 09 08:45 PM |
Winch Launch Fatality | Ed Gaddy[_2_] | Soaring | 3 | June 23rd 09 11:15 PM |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
