On Sep 1, 2:04*am, "Peter Dohm" wrote:
"Morgans" wrote in message ... wrote IMHO there should be NO MORE "open source" aircraft projects, until somebody gets around to implementing a public, vendor-neutral RCS (revision control system) *for aircraft development, so that _any_ designer can submit and begin new projects and contribute to those of friends and peers. This is something that perhaps the EAA could sponsor? I doubt there is enough interest to make it worth EAA's while, or anyone else. If you are designing your own airplane, you probably (or most do) want to do a clean sheet design. *If you know enough to be attempting your own design, then you probably don't need to slow yourself down trying to adapt someone else's *details. *You just do it yourself. Plus, many that are designing and building their own are not capable, or don't desire to put it all down in a computer. *What does that really gain them? *A couple good shop sketches, and start building, is their most likely course of action. *If they do find the need to vary the design to accommodate some needed change, why would they want to take the time to go put the change into the computer. *Only someone who is planning to publish the design, or otherwise go into business would do that, and they sure are not going to be interested in publishing the changes, and giving the whole thing away for free! I won't call you and others like you cheap *******s (g) because I don't know you. *That is kinda' tongue in cheek, but I think the basic idea conveyed is correct. *You just will not find a lot of people giving away something as valuable as an airplane plan for free, when they could be selling it. If you want to buy plans, there are boatloads of people willing to sell them to you for a couple hundred per pop. Buy a few plans and change and scale them like you need them to be, for your needs. Sorry I'm not more optimistic, and I really don't intend to offend. *That just is the way I see it. -- Jim in NC Agreed, and also a little more that I learned the first time that I specified a small project to be formed from sheet aluminum. There's a mildly embarrassing story that I tell on myself from time to time that illustrates just a little of the problem inherent in drawing up nice, plans to produce something that could readily just be hammered together and used. *Sometime in the freshman or sophomore year of mechanical engineering, I took mechanical drafting--and I dare say that I was much above average. It happened that, in class, we were also taught how we might expect sheet metal to accept bends in the course of forming on a brake--which were taught that the determining dimmension would be the center of the cross section of the material with the result that the material inward from the center would compress and the material outward of the center would stretch. *Some years later, I needed to specify the dimensions for a custom chassis for an electronic device. *I confidently drew up the plans, using just a little of the fruit of that earlier education, and when the parts arrived the drill holes were all misplaced--by (drum roll) about half of the thickness of the material. *Of course, I immediately challenged the folks at the shop that did the work, and immediately learned that (another drum roll) I had been taught pure popycock! The moral of that sad little story is that cad drawings, or really any drawings, which are supposed to permit a physical product to be accurately reproduced, need to be drawn and/or reviewed by people who are familiar with the way that such items are manufactured in the real world. *Therefore, if anyone is serious about creating fabrication drawings, I would strongly advise that they start out with a few drawings of inexpensive sample parts that can be used to evaluate some of the discrepancies that could occur; and then pass the drawings, without any special explanation, to someone experienced in fabricating from drawings. *The result will determine whether the drawings conform to real world practices. That is not to disparage the Open Source idea. *At least in the case of computer software, Open Source seems to result in at least as good a product as closed source proprietary and has the added feature that the program and everything created from it won't become useless in the event that the originating company ceases operations. Just my rather long $0.02 Peter Thanks for the input Peter, I understand your point, that there are caveats in fabrication that are often overlooked in the design phase. But that is common in the design of everything really. Experience mitigates this over time, which is part of the reason for a good revision control system (RCS). Even with experience, a large project is going to have some revision, and this may simply be a matter of diversification in fabrications techniques from shop to shop. As you mentioned above you were tought wrong. But perhaps there is a fabrication process where what your were taught does apply? (invariably, there are some cases where different shops would produce differing products based on the same CAD, if only for a lack of exactitutde on the designers part) If you were using a revision control system, you would fork (duplicate) the design of the effected part only, and would subsequently maintain two documents, each notated to indicate their preferred manufacturing method. In this way, all future development work has the option of selecting which branch of the design tree applies to their situation. This is the core purpose of an RCS, which is what the OP was about. The biggest benefit of Open Source techniques is good revision control. The primary benefit of good revision control, is that caveats and exceptions are _retained_ in the design, so problems aren't experienced more than once. Incidentally, I've found a few aviation projects in public repositories that are currentiy using "subversion" as an RCS. So what I'm talking about is going on already at a seed level. I'm using "fossil" for some non-aviation related stuff, and hope to eventually use it for a homebuilt project. If so, I'll likely be converting an old out-of-copyright design into CAD, and then using that as a basis for revision. The most likely effect being the revision of a wood wing into aluminum. I don't have the experience, but if it's CAD, I can get review from many experienced designers, and they need not be local. With revision control, the full evolution of the design work is available, which will keep the next guy from making the same mistakes I make along the way. And if the next guy should make a few changes in his revision thats fine. It doesn't prevent my revision from being reproduced in it's exact form. Thanks! Matt |
Take-off practices and procedures... | EridanMan | Piloting | 9 | November 17th 06 04:34 PM |
Take-off practices and procedures... | EridanMan | Piloting | 4 | November 17th 06 12:45 PM |
Student practices landing with gear up | steve | Piloting | 53 | August 19th 06 04:46 PM |
