Student practices landing with gear up
Old July 20th 06, 05:18 AM posted to rec.aviation.piloting
steve[_1_]
Default Student practices landing with gear up
Bummer,
I had the Arrow reserved with the flight center I use, for next week and for
a couple of days in August.
They just sent me an email stating that a student pilot from the flight
center they share it with, landed it with the gear up. How embarrassing,
especially since the plane has an automatic gear down deployment once it
drops below 100mph and the manifold and rpm resemble a landing
configuration. He/she must have shut it off. It has a loud alarm that sounds
off in that situation, so I don't know what might have happened..
Steve
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
Old July 20th 06, 05:29 AM posted to rec.aviation.piloting
Flyingmonk[_1_]
steve wrote:
Bummer,
Steve
- Leonardo Da Vinci
I think the statement(I can't remember who said it first) goes
something like this, "First rule of thumb when designing fool proof
anything is never to underestimate a fool."
Monk
Old July 20th 06, 06:24 AM posted to rec.aviation.piloting
BTIZ
I thought that auto extend feature had been disabled by a SB on most
Arrows.. maybe only the older ones..
BT
"steve" wrote in message
Bummer,
for a couple of days in August.
sounds off in that situation, so I don't know what might have happened..
Steve
- Leonardo Da Vinci
Old July 20th 06, 06:27 AM posted to rec.aviation.piloting
Robert M. Gary
BT
Isn't that the one that had the battle of the SBs? SB says disable it,
SB says reenable it, SB says disable it etc?
Old July 20th 06, 08:11 AM posted to rec.aviation.piloting
Peter Duniho
Depending on what else he was doing with the airplane that flight, it might
not be surprising for the automatic deployment to be disabled temporarily
(I'm assuming that since you're familiar with the airplane, you know whether
it's been permanently disabled, and that it hasn't been). It's common to
disable the auto deployment when practicing power-on stalls, for example (so
the gear doesn't drop while you get the airplane slowed down and otherwise
configured for the stall).
As for the warning horn, most retractable gear airplanes are equipped with
gear warning horns, and pilots frequently manage to ignore them. It seems
to me that in many gear-up landings, they are preceded by some sort of
distraction. Something odd about the traffic pattern entry, or having to
extend the pattern, or something along those lines. Of course, when a
distraction happens, the pilot may well find himself having to focus even
more, and this focus can result in not being aware of a warning horn.
Ironic, since that's just when the horn is most needed.
Anyway, I'd say that history has shown us that the airplane features you
mention (auto deply and warning horn) are not 100% effective in preventing
gear-up landings. Too often, the very factors that led to the gear-up
landing in the first place are related to why those features don't wind up
being useful.
Pete
Old July 20th 06, 03:27 PM posted to rec.aviation.piloting
Paul Tomblin
Two possibilities:
- he disabled it when he was doing air work earlier OR
- he landed at 90 knots and half throttle.
You had me at
print("Hello World\n");
Old July 20th 06, 04:11 PM posted to rec.aviation.piloting
Peter R.
snip
With regards to my Bonanza, this horn is practically useless as it will
only sound when manifold pressure drops below 12 inches, well below the
green arc on the MP gauge (implying that for the majority of the approach
the horn would be silent).
It is not until power is pulled almost all the way back, which in my case
typically is less than 50 feet above the runway or about a second before
touchdown.
Peter
Old July 20th 06, 04:13 PM posted to rec.aviation.piloting
Peter R.
touchdown.
Sorry, didn't finish my thought he
It is not until power is pulled almost all the way back that MP drops below
12 inches and into warning horn range.
Peter
Old July 20th 06, 04:27 PM posted to rec.aviation.piloting
Jose[_1_]
touchdown.
You land with a vertical speed of fifty feet per second? I don't think
it matters whether it's gear up or down at that point!
Jose
The monkey turns the crank and thinks he's making the music.
Old July 20th 06, 04:34 PM posted to rec.aviation.piloting
Peter R.
touchdown.
LESS than. I guess the tears in your eyes from your uncontrollable
laughter perhaps prevented you from reading that part.
Peter
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
landing gear interface. Steve Franklin Piloting 6 September 24th 05 04:26 AM
Navy? C2/COD makes single engine, gear up landing. Dave S Piloting 20 August 20th 05 11:27 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
