Mike Adams writes:
About the only exception I can think of is an ILS that's slightly offset from the runway alignment, but I don't know of one that's more than a few degrees. Even in that case, you can still practice the instrument approach under VFR in VMC. I'm not sure why an offset ILS would be an exception, since there is still a corresponding instrument procedure to practice. |
Mxsmanic wrote:
Mike Adams writes: About the only exception I can think of is an ILS that's slightly offset from the runway alignment, but I don't know of one that's more than a few degrees. Even in that case, you can still practice the instrument approach under VFR in VMC. I'm not sure why an offset ILS would be an exception, since there is still a corresponding instrument procedure to practice. The point you raised was about tracking the ILS while making a straight in VFR approach. My only point was that if it's an offset localizer (in the extreme) the tower might not think you're making a straight in approach. If the tower has approved you doing a practice ILS approach that's a different situation. Mike |
Mike Adams wrote
The point you raised was about tracking the ILS while making a straight in VFR approach. My only point was that if it's an offset localizer (in the extreme) the tower might not think you're making a straight in approach. If the tower has approved you doing a practice ILS approach that's a different situation. The term "straight-in approach" is used rather broadly just to distinguish the approach from "flying the pattern" or "join a left base", etc. Bob Moore |
Mike Adams writes:
The point you raised was about tracking the ILS while making a straight in VFR approach. My only point was that if it's an offset localizer (in the extreme) the tower might not think you're making a straight in approach. If the tower has approved you doing a practice ILS approach that's a different situation. The large fudge factor allowed for straight-in VFR is so generous that it should easily cover the small offset of an offset localizer or LDA approach. Even an LDA approach should not be more than 6 degrees from the centerline, which is trivial compared with VFR tolerances. "Straight-in" doesn't mean that you have to be on the centerline 20 miles out (although you can be if you want). It just means that you're not flying the pattern. However, your point is taken, in that some instrument procedures might depart sufficiently from normal VFR behavior that you'll probably want ATC to approve of them before you practice them under VFR, so that they know why you don't seem to be following the pattern. A circling approach would be one example. That's why I mentioned an ILS approach, which looks just like a straight-in approach under VFR. |
On Sep 29, 9:01*am, Mxsmanic wrote:
That's why I mentioned an ILS approach, which looks just like a straight-in approach under VFR. WRONG. YOU OBVIOUSLY ARE NOT CONSIDERING THERE IS MORE TO A GLIDE SLOPE TO AN ILS APPROACH IN RELATIONSHIP TO WHERE YOU ARE. |
On Sep 29, 5:16*pm, Mxsmanic wrote:
writes: WRONG. YOU OBVIOUSLY ARE NOT CONSIDERING THERE IS MORE TO A GLIDE SLOPE TO AN ILS APPROACH IN RELATIONSHIP TO WHERE YOU ARE. What? EXACTLY WHAT I SAID. |
LAS approaches | Ron Garret | Instrument Flight Rules | 10 | March 28th 09 06:46 AM |
My First GPS Approaches | john smith | Instrument Flight Rules | 10 | November 9th 04 09:14 PM |
ILS PRM approaches | Riddler | Instrument Flight Rules | 2 | October 28th 04 12:37 PM |
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China | Dionaea muscipula | Military Aviation | 0 | July 21st 04 08:18 AM |
NDB approaches -- what are they good for? | Dylan Smith | Instrument Flight Rules | 15 | July 10th 03 09:15 PM |
