Transponder antenna installations
Old February 7th 11, 03:18 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Transponder antenna installations
On Feb 6, 9:57*am, jcarlyle wrote:
JJ, please don't use RG-58 for a transponder cable - it has very high
attenuation per foot. Times Microwave LM240 is a much better choice,
with only 1/3 of the attenuation of RG-58 at 1 GHz. I usually use
Times Microwave LM300, with only 1/4 the attenuation of RG-58, but it
has double the diameter. Both of these cables have a greater than 20
year life outdoors.
-john
On Feb 6, 9:07 am, JJ Sinclair wrote:
I second the L-2, di-pole antenna suggestion, all inside with nothing
sticking out to get ripped off. Carve a1"X 1"X4" balsawood block so
that it matches the inside curve of your non-carbon fuselage, then
glue the antenna vertical to the flat side and the curved side to the
inside aft fuselage. *Keep it about 6" away from metal objects like
your elevator push-rod, etc. Secure the RG-58 lead so that it can't
get tangled with controls and you're good to go.
Hope this helps,
JJ- Hide quoted text -
- Show quoted text -
The Becker 4401-175 manual does say that RG-223/U is preferred over
RGU-58, but it doesn't mention LM-240? As a mechanic I am bound to
follow the appropriate tech data. Does LM-240 use the same BNC
fittings I have in stock? Can I use my crimper? What would my log book
entry say? Installed Becker 4401-175 transponder in accordance with
opinions found on ras?
:) JJ
Old February 7th 11, 04:46 PM posted to rec.aviation.soaring
Willy VINKEN
On Mon, 7 Feb 2011 06:18:57 -0800 (PST), JJ Sinclair
year life outdoors.
-john
Hope this helps,
:) JJ
'Aircell 5' is a good substitute for plain vanilla RG 58/U coax
cable.
It fits standard BNC connectors.
Attenuation at 1000 MHz is about 32 dB/100m (compared to 54 for RG58)
Willy VINKEN -ON5WV-
Old February 7th 11, 09:27 PM posted to rec.aviation.soaring
Grider Pirate
year life outdoors.
-john
Hope this helps,
:) JJ
*'Aircell 5' *is a good substitute for plain vanilla RG 58/U coax
cable.
Willy VINKEN *-ON5WV-- Hide quoted text -
....and Aircell 5 IS listed in the manual for the Trig transponders.
RG-58 is not.
Old February 7th 11, 11:07 PM posted to rec.aviation.soaring
year life outdoors.
-john
Hope this helps,
:) JJ
cable.
RG-58 is not.
We use RG 400 for our transponder antenna cables. Trig says it is
good for up to 8'4".....(So does Garmin.)
Since you can mount the trig transmitter box wherever you need,
staying less than 8' is easy.
Cookie
Old February 7th 11, 11:32 PM posted to rec.aviation.soaring
jcarlyle
I hate to break it to you, but a Becker 4401-175 installed using RG-58
as an antenna line violates Becker’s instructions. They state in
paragraph 5C that only RG-223 is to be used with the 4401-175. RG-58
can only be used with a 4401-250. Don’t overlook that you also must
comply with paragraph 6E, where you must check the power at the
antenna end of the cable. I’d bet that a 4401-175 using RG-58 will not
meet Becker’s power spec of 18.5 dBW.
As far as the non-mention of LM240 in the Becker manual, I’d bet
you’re allowed as an A&P to attach data showing that LM240 exceeds the
performance of RG-223. This data, combined with the mandatory power
test proving that the 4401-175 installed using LM240 exceeds the
Becker requirement of 18.5 dBW at the antenna end of the cable, would
make you golden.
Unfortunately, you have to buy male BNC and male TNC crimp connectors
when you buy the LM240. They’re a buck more expensive than RG-58
connectors. But your crimper will definitely work.
Your log book entry would simply say that the Becker 4401-175 was
installed in accordance with the manufacturer’s instructions, except
for the use of an antenna cable that exceeds the manufacturer’s cable
specifications which results in greater power being delivered to the
antenna. I guess you could attribute the idea of using a better cable
to RAS, if you liked – humor shouldn’t a violation of the A&P code, is
it?
-John
:) JJ
Old February 8th 11, 08:04 AM posted to rec.aviation.soaring
Alan[_6_]
In article jcarlyle writes:
as an antenna line violates Becker's instructions. They state in
can only be used with a 4401-250. Don't overlook that you also must
antenna end of the cable. I'd bet that a 4401-175 using RG-58 will not
meet Becker's power spec of 18.5 dBW.
Remember to account for the greater loss of the cable after 10 - 20 years.
As far as the non-mention of LM240 in the Becker manual, I'd bet
you're allowed as an A&P to attach data showing that LM240 exceeds the
make you golden.
when you buy the LM240. They're a buck more expensive than RG-58
I doubt it. LMR 240 is larger in diameter than RG-58. The crimper for
RG-59 might be a closer fit.
installed in accordance with the manufacturer's instructions, except
for the use of an antenna cable that exceeds the manufacturer's cable
to RAS, if you liked =96 humor shouldn't a violation of the A&P code, is
it?
The problem is that "better" isn't just lower loss per foot when the cable
is new. There may be a lot of other factors that the manufacturer took into
account with their cable selection. "Better" needs to be better in all of
these factors.
The transponder may need a minimum amount of loss in the coax to ensure that
the SWR seen by the transmitter is low enough in case something gets near the
antenna. (This would protect both the transmitter, and the receiver, as a mismatch
at the duplexer often reduces the isolation between the transmitter output and the
receiver input.)
-John
:) JJ
I suspect it LMR 240 would work better than the other cables, both in loss and
service life, but I don't know it. As JJ notes, he doesn't know it for sure, and
and would need to.
Alan
Old February 8th 11, 03:19 PM posted to rec.aviation.soaring
jcarlyle
Alan,
The best way to answer is to quote from section 5.11.2 of the Trig
installation manual. They state that excessive cable loss will degrade
both transmitter output power and receiver sensitivity. Then they
define the three qualities of an acceptable cable:
(1) less than 1.5 dB loss for the run length,
(2) a characteristic impedance of 50 ohms, and
(3) double braid screens, or a foil and braid screen.
They then say that their table of maximum usable lengths for common
cable types is a guide only, and tell you to refer to manufacturer’s
data sheets for your specific chosen cable. This is clearly permission
to choose your cable type, as long as it meets Trig’s three acceptance
criteria above as backed up by specific manufacturer’s data.
As for “knowing” about cables, like anything else you need to do
research and get educated. I’ve tried to let this forum know that
there are much better choices for microwave cable than RG-58 and
RG-400. Naturally, people will do as they wish, even to the extent of
tossing away transponder output power and getting less receiver
sensitivity. It may work out OK, or it might possibly be a link in an
accident chain someday. I have the satisfaction of knowing that in my
transponder installations pilots are getting 175 W transponders that
meet or exceed their performance specifications for just $20 extra in
cable.
-John
these factors.
receiver input.)
and would need to.
Alan
Old December 31st 19, 07:04 PM posted to rec.aviation.soaring
A bit off topic but when I bought my glider the transponder antenna (flat L2 type) was mounted under the seatpan on the "floor" of the fuselage. After reading some links in this thread I see that, according to the manufacturer, the antenna should be mounted vertically. Where would one typically do this? There aren't many flat vertical surfaces other than the main bulkhead. Glass, not carbon fiber, ship. This is my first glider with a transponder and I admit ignorance on the topic.
Old December 31st 19, 08:16 PM posted to rec.aviation.soaring
Darryl Ramm
Yep, wrong polarization orientation, and the testicle thing.
As you likely are working out there often is no *great* place to mount an antenna.
Many people would make up a vertical mount out of plywood or fiberglass or just a block of balsa and find a place on one side of the fuselage to mount this down the tail boom to mount this. You want to avoid the antenna being near conductive components and that is often a problem finding space away from control linkage and other hardware, and you have rudder cables and elevator etc. running down the fuselage. Have a look around and see. It may be better to mount an external 1/4 wave antenna with internal ground plane.....
If you end up with longer coax runs pay attention to using a correct high-spec cable, especially with Trig transponders. And secure the cable well so there is no movement.
Old December 31st 19, 08:17 PM posted to rec.aviation.soaring
SoaringXCellence
I cut a piece of balsa wood that matched the curve of the fuselage, aft of the landing gear. I bonded the L2 to the wood and then the wood to the fuselage. The biggest challenge was getting the antenna cable routed, and then plugged into the antenna.
Mike
Transponder Antenna Rick Fuller Soaring 6 January 30th 08 07:03 PM
Transponder Antenna Location [email protected] Soaring 15 January 17th 08 07:56 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 05:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 09:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 04:32 AM
