Hydraulic brake problems. The disc brake on my D2b has provided only
very limited stopping ability for a year or so now. When attempting to put on the brakes the brake handle moves all the way back to the stick grip. We have repeatedly attempted to eliminate air in the system by pumping .4 fluid up through the wheel cylinder drain nipple. We have sucked the system dry by vacuum applied, also to the same nipple. We have checked the nipple itself for blockage. We replaced the master cylinder. We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. Nothing seems to make any difference. IT |
On Mar 27, 9:34*am, Dick wrote:
Hydraulic brake problems. *The disc brake on my D2b has provided only very limited stopping ability for a year or so now. *When attempting to put on the brakes the brake handle moves all the way back to the stick grip. *We have repeatedly attempted to eliminate air in the system by pumping .4 fluid up through the wheel cylinder drain nipple. *We have sucked the system dry by vacuum applied, also to the same nipple. *We have checked the nipple itself for blockage. *We replaced the master cylinder. *We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. *Nothing seems to make any difference. *IT Sounds like you are doing everything right. I assume you checked for wear of the pads? Easy to replace them and always a good idea. Also it is easy to replace the O-ring on the brake master cylinder. However you would see seepage atounf the Master cylinder if it is bad. I change them every few years because they do get old and hard. good luck, Dan WO |
![]() We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. *Nothing seems to make any difference. * In addition to pad wear, discs get thinned over time as well. Make sure the disc and pads are up to spec'd thicknesses. It is possible the combo of both can run the piston out of useful travel. Also verify the cable is transmitting full force, a frayed/worn out cable can have enough strength to plunge the piston, but so much elasticity that it won't do it with much force, especially if it's one of those wussy bicycle cables and not the stout Boden (motorcycle) variety. -Paul |
On Mar 27, 10:58*am, sisu1a wrote:
We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. *Nothing seems to make any difference. * In addition to pad wear, discs get thinned over time as well. Make sure the disc and pads are up to spec'd thicknesses. It is possible the combo of both can run the piston out of useful travel. Also verify the cable is transmitting full force, a frayed/worn out cable can have enough strength to plunge the piston, but so much elasticity that it won't do it with much force, especially if it's one of those wussy bicycle cables and not the stout Boden (motorcycle) variety. -Paul Look at your caliper real close to verify that your line comes out the very top of the piston cavity. If not you will need to make the line as high as possible or even remove it and position it so the line is high and then bleed again. |
On Mar 27, 2:02*pm, glidergeek wrote:
On Mar 27, 10:58*am, sisu1a wrote: We checked the cable to make sure there was no slack yet the abbreviated handle plunger was virtually in contact with the piston in the master cylinder and the master cylinder piston was moving. *Nothing seems to make any difference. * In addition to pad wear, discs get thinned over time as well. Make sure the disc and pads are up to spec'd thicknesses. It is possible the combo of both can run the piston out of useful travel. Also verify the cable is transmitting full force, a frayed/worn out cable can have enough strength to plunge the piston, but so much elasticity that it won't do it with much force, especially if it's one of those wussy bicycle cables and not the stout Boden (motorcycle) variety. -Paul Look at your caliper real close to verify that your line comes out the very top of the piston cavity. If not you will need to make the line as high as possible or even remove it and position it so the line is high and then bleed again. The hydraulic brake failed on my Discus 2 also a year or so ago and we finally installed a repair kit on the master cylinder. We had lost one of the o-rings and the fix worked perfectly. Bleeding the system wasn't easy and we only got success after feeding fluid under pressure from the slave. i wonder if you effectively bled the system after installing the new master cylinder? Mike |
Here my experience on my V2C 3U.
2 years ago, my brake was very tight and would respond immediately with no slack. Last season, I noticed brake fluid dripping from a drain hole in the bottom of the fuselage. Also my brake action deteriorated gradually. I had not replaced the brake fluid (like I never do on my cars either) and the fluid had gummed and was leaking around the master brake cylinder. I replaced the original 20mm piston Magura master cylinder with a new 16mm piston unit (mounted standard on BMW motorcycles) . After extensive bleeding as described above, I still could not regain real pressure. (I realize that the smaller master piston does require more travel.) However, at further inspection, I noticed that the brake pad on the Cleveland caliper would withdraw upon release of the brake handle. In other words, the caliper does not rest tight and at each brake action fluid volume needs to be filled to bring the brake pads tight, before brake pressure can be build up. I decide to completely disassemble the Cleveland assembly to check for gumming up and for overhaul. Turns out there is hardly anything in the Cleveland assembly. Just one standard O-ring. New O-rings ordered. Caliper disassembled. Piston carefully pushed out with a little airpressure from a small 12 V tire compressor. It turned out that the aluminum caliper and piston had been corroded substantially. I presume from condensation moisture from high altitude flying and mixing with the hydraulic fluid. I lightly sanded, with 800 sand paper, the corroded section, where the O-ring sits. Installed the new O-ring and re-assembled. After again extensive bleeding (upwards from the caliper to the reservoir), I now have pressure. I still need to test fly to see how well the overhaul works. I am not yet sure if this has resolve all problems as I now have substantially more "squeeze" than before. But as mentioned, this could be partly due to the smaller master piston, which would give more throw but also more force/pressure. Summarizing: My first problem was the leaking master cylinder. After that next problem was piston in the Cleveland caliper retracting upon brake lever release (instead of taking new fluid from the reservoir). I am still not sure if this retracting is a problem of the new master cylinder or a problem of the corroded Cleveland brake caliper. 3U |
On 3/28/2011 1:46 AM, weersch wrote:
But as mentioned, this could be partly due to the smaller master piston, which would give more throw but also more force/pressure. Summarizing: My first problem was the leaking master cylinder. After that next problem was piston in the Cleveland caliper retracting upon brake lever release (instead of taking new fluid from the reservoir). I am still not sure if this retracting is a problem of the new master cylinder or a problem of the corroded Cleveland brake caliper. I had a similar problem with my Cleveland brake system on my ASH 26E. It worked fine for years, but one day it was very "spongy" after rigging. I loosened the cap on the fluid reservoir, and in just two brake applications, it was working fine. I cleaned the cap and the vent in it, and have had no further problems in the seven years since then. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
It is possible the combo of both can run the piston out of useful travel. Don't see how that is possible. Hydraulic disk brake systems are self compensating for wear. As the pads and disk wear the system fluid volume increases and fluid transfers from the master cylinder reservoir when the piston is in the retracted position. There is no limit on the piston travel of a Cleveland caliper. It just keeps going until it is ejected from the O ring seal. Andy |
![]() Don't see how that is possible. *Hydraulic disk brake systems are self compensating for wear. * So long at the reservoir is vented. Most use a bleeder cap (usually just a pinhole in the fill plug), but not all. Ones without bleeder caps need to be 'burped' every so often since it is not allowing air into the reservoir (above the fluid) to allow the displacement needed for the pads to self adjust as they wear. -Paul |
I had the same problem with my Ventus and it took me a long
time to figure it out. Eventually i discovered that the plunger which enters the master cylinder was dry and actually frozen in position so that no matter what i did to the bowdan cable, actuating lever, caliper had no effect. Mine was so tight I actually broke a hand lever trying to stop once! Its a very simple fix. Remove the master cylinder, slightly withdraw actuating plunger, clean it up and lube it with Dow Corning or similar silicone grease. That is the fix! Then make sure you lube that bugger each annual. Please post if it works! John Sullivan, UFO |
Bleeding LS4 wheel brake hydraulic system | David Starer[_3_] | Soaring | 1 | April 3rd 10 04:06 PM |
hydraulic brake actuation | Brad[_2_] | Soaring | 15 | January 9th 09 05:46 AM |
Hydraulic trailer surge brakes means no parking brake? | [email protected] | Soaring | 11 | March 18th 08 04:19 AM |
Hydraulic Pump | [email protected] | General Aviation | 2 | March 28th 06 05:09 AM |
AP: Navy Jet Has Severe Brake Problems | Otis Willie | Naval Aviation | 0 | August 6th 05 12:20 AM |
