On Nov 1, 10:58*pm, HIPAR wrote:
On Nov 1, 7:54*pm, "Ed M." wrote: On Nov 1, 3:21*pm, Alan Browne wrote: That wouldn't fly far - there are only so many viable gold codes - though possibly many more on L5 with its longer code length. There are actually around 500 balanced (roughly equal number of 0s and 1s) Gold codes in GPS, if you ignore the 2-tap mechanization shown in the ICD. *The 4-asterisk footnote was added to Tables 3-I and 3-II a few years ago when the first list of expanded codes was published in the ICD ( " **** The two-tap coder utilized here is only an example implementation that generates a limited set of valid C/A codes."). With zero Doppler difference between two PRNs, any pair of the 500 or so balanced Gold codes would have the same peak cross-correlations. The cross-correlation peak comes up a few dB at some Doppler differences. *Gold's 1967 papers showed that the zero-Doppler peak for a 10-bit code is limited to 20*log(65/1023) of 20*log(63/1023), where 63 and 65 represent the excess of bit by bit agreements over disagreements (or vice versa) between the two codes at a given time offset. *His papers also showed the probability of occurrence. The log works out to about -24 dB. *But user antenna gain, as well as differences in satellite power, can bring the peak up more. The bigger issue is that the broadcast ephemeris doesn't include the PRN number. *It's just assumed by the receiver that it's tracking the one it wanted. *But that's not a deficiency of the Gold codes, nor really a deficiency of the original signal design, which is quite elegant -- an awful lot of information packed into very few bits. All just a quibble -- you're right that the newer signals with longer codes will work better. I suppose if cross correlation becomes a problem, it can be mitigated by placing the conflicting satellites in antipodal positions. Current L5 PRN assignments: http://www.losangeles.af.mil/shared/...070530-041.pdf And L1 C/A: http://www.losangeles.af.mil/shared/...101124-042.pdf Of course, *'modernized signal' would be the operative concept for a universal open L1 signal conforming with a common ICD. *Shame it will never happen. It's a 'minor miracle' that SBAS has been standardized. http://www.elisanet.fi/master.naviga...S_Coverage.jpg --- *CHAS One interesting question, military and L5 signals both use a 10 mega chip/sec signal, clearly better for jamming tolerance and ability to acquire a signal under challenging conditions, but does 50 10 mega chip/sec signals being received at the same band perform better than 50 1 mega chip/sec signals ? As far as the common ICD, I believe this will take 20-30 years, and will happen when L1 C/A gets retired and replaced by a brand new signal, perhaps a 10 mega chip/sec signal, broadcast by all GPS satellites (one can hope...). Also there has been talk about a signal in the 5GHz band, maybe one day we could have a sane, normalized signal there too. A 5GHz signal would improve IONO corrections hugely, due to the multi GHz jump in frequency. SBAS has a common ICD due to FAA having no proprietary interest in the signal, quite on the opposite, by making SBAS signal structure a worldwide standard benefits the early manufacturers (Americans) to come to market, and due to the obvious requirement that an American aircraft needs to be able to fly elsewhere in the world and use the other SBAS systems, much like ILS/VOR/NDB/DME allow that today and vice-versa. The requirements for revision control, documentation and testing of software onboard aircraft navigation systems is 100% assinine and extremely expensive. Talk about burying yourself in paperwork. But are the ICD differences between GPS/Galileo and QZSS that big ? It seems to me that the differences are 100% software stuff, nothing to do with acquiring and tracking the signal, just in the higher level functions, like a few ifs in the higher level software of a receiver. I have not read those ICDs, I'm really asking. Marcelo Pacheco |
Galaxy XV / PRN 135 geo arrives at 133.1W, WAAS ranging back to 7.5meter UDRE | macpacheco | Instrument Flight Rules | 3 | April 6th 11 07:17 PM |
Precision Airmotive LLC | Jerry Springer | Home Built | 53 | November 11th 07 08:41 PM |
Some IFR GPS's no longer useable | kevmor | Instrument Flight Rules | 2 | May 28th 07 02:27 AM |
Non-precision approach without a published MAP? | Peter R. | Instrument Flight Rules | 20 | August 1st 06 08:09 AM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
