Why is total energy difficult using delta pitot pressure?
Old July 23rd 12, 03:11 AM posted to rec.aviation.soaring
Default Why is total energy difficult using delta pitot pressure?
The subject says it all
Bill Snead
6W
Old July 23rd 12, 03:35 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
It wasn't for me, using a 302 on my ASH 26 E, as it has a very accurate
pitot/static system. If it's not accurate, it's going to be harder.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old July 23rd 12, 09:18 PM posted to rec.aviation.soaring
Steve Koerner
A pitot connection alone cannot give you total energy. In fact, it gives you backwards total energy. Kinetic energy increase results increased pitot pressure yet potential energy increase is associated with reduced pitot pressure. This problem can get resolved when you also connect to a static port and do the math.
Now, pitot ports are fairly foolproof and always give good signal. But, not so for static ports. Static ports are easily fooled by changes in AOA and yaw. On fuselage static ports are usually hopeless for use in delta P varios. The best bet for a static port are those tied to a modern triple probe. And that begs the question: why bother if you are going to install a modern triple probe anyway?
Old July 24th 12, 12:17 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
The triple probe is usually in the prop wash of a self-launcher,
rendering it almost worthless under power. Using the fuselage
pitot/static avoids that problem. That's why I do it, but I'm not sure
the original poster had in mind.
email me)
Old July 27th 12, 09:35 AM posted to rec.aviation.soaring
Jim White[_3_]
Why do you need total energy when running your engine?
Old July 27th 12, 10:06 AM posted to rec.aviation.soaring
Darryl Ramm
Because you want to find lift, put the noise maker away and go soaring. An electronic compensated C302 works great for doing that while under power as described. The -MG version of the 302 with loud external speaker mounted near the pilot's head can be heard over engine noise/and through most headsets.
Darryl
Old July 28th 12, 01:17 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
The TE response isn't really needed because I'm flying at a fairly
steady airspeed; instead, the problem is the prop wash makes the
pressure at the probe very unsteady, and that makes the vario needle and
audio very unsteady, making the vario almost useless for finding and
centering a thermal.
Some pilots work around the problem with a panel-mounted pneumatic
switch to connect the vario TE input to cockpit static, and I'm told
that works well enough.
email me)
Old July 26th 12, 05:16 AM posted to rec.aviation.soaring
Bill Snead
6W
I would say 90 percent plus of competition pilots use a vacuum total energy probe. From the posts, I would say it is simpler. To use the pitot you must have a good pitot and static system plus a way to reverse the pressure delta (electronic or diaphragms). Any thing else? It also sounds like the pitot input can be made to work. Do you think that the drag from the vacuum probes is very great?
Bill Snead
6W
Westerboer electronic total energy vario kd6veb Soaring 3 September 11th 11 12:08 AM
Electronic total energy vario kd6veb Soaring 13 July 19th 11 11:23 PM
Diafragm type total energy compensator JC Soaring 3 March 1st 11 12:51 AM
Total energy probe orientation? John Bojack[_2_] Soaring 4 June 5th 09 02:33 PM
varios not using a total energy probe Robert Soaring 20 April 25th 04 11:24 PM
