Using a nook for xcsoar
Old October 12th 12, 07:31 PM posted to rec.aviation.soaring
Marc
Default Using a nook for xcsoar
On Oct 12, 10:23*am, wrote:
This has piqued my interest some and I was wondering whether an old Cambridge 10, 20, or 25 model that outputs serial GPS could be used as the GPS engine for the Nook?
I know it would not have the vario information but would it be as accurate as a standalone Dell Streak say?
The problem with the CAI 10/20/25 is that they don't provide an NMEA
sentence that contains GPS altitude, and the most common firmware
versions only output pressure altitude if you send them a special
handshake sequence which (to my knowledge) has not been revealed to
3rd parties. So, you could see your position on the Nook, but you'd
likely be out of luck on altitude...
Marc
Old October 14th 12, 05:09 PM posted to rec.aviation.soaring
Kimmo Hytoenen
My experience is, that CAI and Volkslogger GPS signals are quite a
lot delayed. Might be slow communication speed, or filtering. This
makes it difficult to use moving map for navigation. FLARM works
much better.
At 18:31 12 October 2012, Marc wrote:
an old
Cambr=
the GPS
e=
ngine for the Nook?
as
accurat=
CAI-302 and XCSoar Dan Marotta Soaring 7 March 29th 12 09:55 PM
xcsoar [email protected] Soaring 40 August 13th 09 09:01 PM
XCSoar in the UK Martin Gregorie[_5_] Soaring 0 August 10th 09 10:46 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 03:36 PM
XCSoar jorgie Soaring 2 November 2nd 04 12:05 AM
