Not to a Nexus 7, but to other Android devices and it works as expected. You can use either Bluetooth or a IOIO board for that.
Is an IOIO board a "plug and play" type of hardware. Can I plug it in and configure the ports in the android device? I saw a video on youtube with a Colibri II, V7, and Dell Streak.
On Friday, November 30, 2012 2:46:34 PM UTC+1, Lucky812 wrote:
Is an IOIO board a "plug and play" type of hardware. Can I plug it in and configure the ports in the android device? I saw a video on youtube with a Colibri II, V7, and Dell Streak. -- Lucky812 The IOIO is plug and play in the sense that you do not need to load any special firmware for gliding purposes. The standard firmware should be used. However it will require some soldering, mounting in a box etc. The soartronic shield probably reduces the soldering work considerably |
New Nexus 7 with xc soar. | glider12321 | Soaring | 29 | December 17th 12 04:27 PM |
Nexus program of any use flying? | Paul kgyy | Piloting | 3 | September 9th 08 06:47 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | Instrument Flight Rules | 5 | September 26th 04 07:09 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | General Aviation | 4 | September 26th 04 07:09 PM |
Connecting a GNS 430/530 to a PC | PA34 F-GFTF | Aviation Marketplace | 7 | September 25th 04 04:38 AM |
