METAR Question
Old January 25th 13, 05:33 PM
test_driver test_driver is offline
Junior Member
First recorded activity by AviationBanter: Jan 2013
I thought I would let you all know that I figured out what that code means in the METAR.
The code deals with Ice Accretion:
Hourly Ice Accretion Amount:
Ice accretion for the current hour encoded in hundredths of an inch (0.01 in.) has the following format:
• I1nnn Whe “I” - is the icing indicator for the group “1" - is the reported time period (one hour) “nnn” - is the thickness accumulated to the nearest one-hundredth of an inch (0.01 in.). A trace amount is encoded as “000.”
Three (3-) Hourly Ice Accretion Amount:
• The accretion of ice over the past three hour time period in one-hundredths of an inch (0.01 in.) would have the format: I3nnn Whe “I” - is the icing indicator for the group “3" - is the reported time period (three hours) “nnn” - is the thickness accumulated to the nearest one-hundredth of an inch (0.01 in.). A trace amount is encoded as “000.” The remark may be encoded at the intermediate synoptic times (0300, 0900, 1500, or 2100 UTC). When conditions warrant, the “I3nnn” remark will be encoded immediately following the hourly ice accretion amount (I1nnn).
Six (6-) Hourly Ice Accretion Amount:
• The accretion of ice over the past six hour time period in one-hundredths of an inch (0.01 in.) will have the format: I6nnn Whe “I” - is the icing indicator for the group “6" - is the reported time period (six hours) “nnn” - is the thickness accumulated to the nearest one-hundredth of an inch (0.01 in.). A trace amount is encoded as “000.” The remark may be encoded at the mandatory synoptic times (0600, 1200, 1800, or 0000 UTC). When conditions warrant, the “I6nnn” remark will be encoded immediately following the hourly ice accretion amount (I1nnn).
This could be very helpful to us but the NWS has not installed this update to all stations yet.
Old January 26th 13, 12:03 AM posted to rec.aviation.piloting
Don Poitras
Default METAR Question
Where did you find that defined? I looked in all the spots I
normally used and none of them had Ixxxx.
means in the METAR.
? I1nnn Whe ?I? - is the icing indicator for the group ?1" - is the
reported time period (one hour) ?nnn? - is the thickness accumulated to
encoded as ?000.?
? The accretion of ice over the past three hour time period in
?I? - is the icing indicator for the group ?3" - is the reported time
period (three hours) ?nnn? - is the thickness accumulated to the nearest
one-hundredth of an inch (0.01 in.). A trace amount is encoded as ?000.?
0900, 1500, or 2100 UTC). When conditions warrant, the ?I3nnn? remark
(I1nnn).
? The accretion of ice over the past six hour time period in
?I? - is the icing indicator for the group ?6" - is the reported time
period (six hours) ?nnn? - is the thickness accumulated to the nearest
1800, or 0000 UTC). When conditions warrant, the ?I6nnn? remark will be
test_driver
Don Poitras
Old January 26th 13, 04:56 AM
Junior Member
It was a simple process but I didn't think of it at first because nobody on several forums had any idea and all I thought it would be was a simple "ah someone on a forum will know". So today I decided to called an airport and the lady there didn't know, so then I talked to one of the guys in the tower he wasn't sure but suggested I contact the NWS, the guy there wasn't sure but he said that it just started showing up after an update with the software on their ASOS. That answer gave me the extra piece of info that seems very simple in hind sight, all I had to do was search google for "ASOS I3000" (click the "Search only for ASOS I3000" link) and the first non-ad listing is a pdf from the NOAA about the new software and what the new groups mean, including the ice accretion one.
It goes to show that forums and the internet are great but sometimes you have to go a little beyond to find the answers.
Old January 26th 13, 01:04 PM posted to rec.aviation.piloting
Don Poitras
accretion one.
Excellent. I did that search, but only found pdfs discussing the
testing of the new ASOS software and how the presence of I3000 etc.
was normally an error. e.g.:
http://www.nws.noaa.gov/ops2/Surface..._307_draft.pdf
Please Note: In situations when FZRASN is manually entered in the
Present Weather field, an inappropriate trace accretion amount (I1000,
I3000, I6000) might be entered in the remarks section of the METAR /
SPECI reports. This is a known issue and will be addressed at a later
time.
This is the page I usually go to, but it hasn't been updated since
2008: http://www.ncdc.noaa.gov/oa/climate/...ardecoder.html
The link at the bottom is dead. I tried to get to the "National Weather
Service Office of Systems Operations" pages, but most required a NOAA
login.
I also found this very official looking "handbook", but it's from 2005:
http://www.ofcm.gov/fmh-1/pdf/FMH1.pdf
Don Poitras
Old January 26th 13, 09:30 PM
Junior Member
That is the information that I found also and what I was going off of but then I also got an email reply from the NWS guy I talked to and he confirmed that the I#### is the Ice Accretion group and also that the reason it showed up on the METARs I looked at was because there was trace amounts of ice on the plate.
metar slp reading? Paul kgyy Piloting 8 September 6th 12 11:49 PM
METAR code [email protected] Piloting 19 February 9th 08 11:16 AM
METAR from Mexico Przemek Piloting 2 October 21st 05 02:45 AM
Metar Report [email protected] Instrument Flight Rules 12 August 22nd 05 11:12 AM
Interesting METAR Nathan Young Piloting 1 May 15th 04 03:37 PM
