S-H Ventus light-bar flap position indicator
Old June 9th 13, 07:29 PM posted to rec.aviation.soaring
Tim Taylor
Default S-H Ventus light-bar flap position indicator
In my Ventus 2 there is a thin a fiberglass rod attached to the flap control rod. The thin fiberglass rod runs to a switch reading box behind the seat next to the wheel well where all the sensors are enclosed. I would guess there is a Hall switch magnet attached to the rod inside the box to activate each of the sensors. Designed like this you do not have to try and attach everything near the flap handle.
The flap indicator is one of the surprises that I have found I would hate to do without now.
A low tech system I have seen is to run a plastic or fiberglass rod forward to the panel from the flap control rod and put a mark or the rod and set up a scale on the panel. Pure mechanical with no electronics.
Old June 9th 13, 11:23 PM posted to rec.aviation.soaring
Dan Marotta
On my LAK-17a, the flap settings are engraved into the steel detent
ar: -1, 0, 1, 2, L
What could be simpler?
"Tim Taylor" wrote in message
do without now.
Old June 10th 13, 01:26 AM posted to rec.aviation.soaring
Tim Taylor
It all depends in where you have to look to confirm your flap setting. The flap indicator in the SH allows the pilot to confirm the flap setting and change it effectively on take-off roll without taking your eyes off the tow plane. In a thermal with other gliders I never have to look down to confirm what setting I am in. In the SH "a" models it is harder to see the flap handle location so the position indicator is even more helpful.
Old June 10th 13, 05:15 PM posted to rec.aviation.soaring
Dan Marotta
Don't have to look. I start the takeoff roll at -1 and, as I get aileron
authority, it's simply, "click, click, click". That puts me into
thermalling flap for the tow.
Those are some spiffy setups with the LEDs, however, and, as a sometimes
geek, I may need to make one "just because"!
Old June 10th 13, 12:05 PM posted to rec.aviation.soaring
GC[_2_]
On 10/06/2013 04:29, Tim Taylor wrote:
... A low tech system I have seen is to run a plastic or fiberglass rod
electronics.
Very reliable. Ask any C-47/DC-3 pilot.
GC
Ventus C (1986) - Flap and Gear Indicator Ken Kochanski (KK) Soaring 3 January 19th 10 01:33 PM
Replacing PA28 panel dimmer rheostat/position light switch Mike Noel Owning 4 December 1st 08 12:16 AM
C172N Flap indicator problem onesto Owning 0 July 2nd 06 10:47 AM
EAA position on ADIZ... .Blueskies. Piloting 0 November 2nd 05 12:16 AM
Replacing position light bulbs Mutts Piloting 15 December 30th 03 09:55 PM
