Hypothetical Scenario #1 - Urgent Action required
Old February 9th 14, 02:13 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Hypothetical Scenario #1 - Urgent Action required
On Saturday, February 8, 2014 12:35:58 PM UTC-8, BruceGreeff wrote:
Similar failure happened on a Nimbus 4DM some years ago - on a fast
final glide into Gariep.
Height was low, speed was high (well past Vmo) when they hit a powerful
thermal.
Wings took the shock, but one airbrake actuator failed under the shock
load. It had been damaged by "buzzing" over an extended period - the
caps were not held down properlyso the blade would chatter in it's box
on pull ups. This set up fatigue in the connecting rod which snapped
under the sudden whip motion on the wing.
Due to high speed, no spin departure.
The resulting yaw caused an immediate roll toward the open brake wing.
Pilot correctly assessed the situation, opened the other airbrake and
attempted to recover from the inadvertent barrel roll.
Attempt was unsuccessful, wings failed symmetrically at the outer panel
join, and then a couple of metres from the root - conveniently
preserving the failed actuator and the witness marks... Calculated
failure somewhere on the far side of 300km/h and enormous g.
Fuselage impact was a couple of seconds later - both pilots being
ejected many metres from the point of impact.
Being a DM the resulting fire destroyed much of the confetti that
remained. Somehow, enough of one of the three loggers remained for a
trace to be obtained.
Moral of that story is - check your airbrake actuators for wear and
fatigue - particularly on long flexible wings. And have some respect for
the numbers - they are there for a reason.
Very interesting report, we had a Nimbus 4DM come apart at Minden and both pilots were killed several years back. They got into a death spiral for unknown reasons..............wonder if one spoiler could have popped open to start the spiral? The accident report stated that both spoilers deployed when the ship was near vertical, but now I'm wondering if one was open before the other? I have seen instances where one spoiler came out caused by bending of its pushrod or flexing of drive unit in the root rib, but nothing broke! Would the accident investigator notice a bent rod or flexed root rib in a pile of fiberglass rubble?
JJ
required LD versus required MC to make it home ?? akiley Soaring 56 September 22nd 10 07:48 PM
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
re urgent aog request need urgent pin out dia for KTR 900 a/c not transmitting on P1 P2 ok Stevenatherton Owning 0 November 20th 04 07:36 AM
re urgent aog request need urgent pin out dia for KTR 900 a/c not transmitting on P1 P2 ok Stevenatherton Aviation Marketplace 0 November 20th 04 07:33 AM
OT (It's even controversy free) Here is an interesting scenario. . . Scott Ferrin Military Aviation 3 July 7th 04 02:33 PM
