White LS Sleeves VS Wedekind for ASW 19?
Old May 9th 14, 11:11 PM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Here are the white LS sleeves on my LS1f. They work awesome, they were the first think I changed about the glider after I bought it. https://drive.google.com/file/d/0B1A...it?usp=sharing
Old May 11th 14, 02:35 AM posted to rec.aviation.soaring
Nicholas L
Default White LS Sleeves VS Wedekind for ASW 19?
Where did you buy your White LS sleeves?
How do the White LS sleeves differ from the Uerling sleeves?
Old May 11th 14, 02:39 PM
Member
I got mine from Pacific Aerosport. I think they were $35 each, but that was a few years ago. To me, the great advantage of these sleeves is that they dont require modification to the glider, they simply push onto the end of the control connection, takes 2 seconds. I believe the Uerling sleeves need to be "installed". To hook up the controls, you just push the plunger down, make sure the ball is in place, release the plunger, then rotate the sleeve 180 degrees so the ball can never come out of the socket, regardless of plunger position. Works great.
Old May 19th 14, 05:44 PM posted to rec.aviation.soaring
JohnDeRosa
Just to reiterate, as JS mentioned, the Uerling Sleeves only work on "straight" L'Hotellier fittings. They don't work on 90 degree fittings which my glider has for the ailerons.
I used Uerling Sleeves on the airbrake straight fittings because these were a BITCH to get the original safety pins in while trying to look inside a black hole on a white ship in bright sunlight. The ailerons were much easier and I continued to use the pins until I went Wedekind.
Also, I was told way back when that the Uerling Sleeves needed to be replaced every 2 years. Anyone know about that?
- John
http://aviation.derosaweb.net/wedekind
Wedekind Sleeves for GROB ASTIR CS Juliet11[_2_] Soaring 2 April 1st 13 03:39 PM
Wedekind Safety Sleeves ContestID67 Soaring 3 March 5th 07 12:04 PM
Hints on Securing L'Hotellier with Wedekind Sleeves ContestID67 Soaring 0 December 1st 05 08:29 PM
Wedekind Safety Sleeves Huds Soaring 5 May 8th 05 03:07 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
