1-34 Fuselage Drain Holes
Old May 12th 14, 10:04 PM posted to rec.aviation.soaring
vontresc
Default 1-34 Fuselage Drain Holes
On Monday, May 12, 2014 1:33:41 PM UTC-5, Papa3 wrote:
On Monday, May 12, 2014 1:48:53 PM UTC-4, Steve Leonard wrote:
On Monday, May 12, 2014 12:20:40 PM UTC-5, wrote:
Using a step drill, create about 1/4 diameter drain hole in front of bulkhead where water collects.
Or, behind if the water is moving forward to get to the bulkhead! I have seen gliders with drain holes in the fabric always to the right of the rib. I guess this was a "left wing low" glider!
But, yes, to Hank's advice. Add a small hole where appropriate. And quarter inch sounds about right to me, too.
And FWIW, make sure that the "maintenance guy/gal" for that ship keeps them clean. A number of our club gliders have drain holes in various places that get plugged up pretty regularly. Spoiler boxes on a particular glass two place leap to mind.
Sounds like I'll need to talk to our A&P to put some carefully placed drain holes in there. Talked to Kyle at K&L when I ordered the replacement release return spring, and he said that they have no "official" method of doing this. So I guess it's a mod IAW AC43.13 then.
Peter
Curtis oil quick drain Mike Noel Owning 2 August 27th 09 12:04 AM
Drain holes under Schleicher seatpans Tuno Soaring 15 January 12th 09 09:50 PM
Limiting battery drain by using what? joesimmers Soaring 2 July 23rd 08 03:31 PM
Gordon's Pics : the B-24 wreckage bullet holes B24-fatal-upside-down-rear-fuselage Dave Kearton Aviation Photos 0 April 22nd 07 12:49 AM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 02:19 AM
