On Tue, 09 Sep 2014 07:59:41 GMT, Skywise wrote:
Larry Dighera wrote in : She also said the hydrogen would be compressed to ten bar, which would raise its energy density comparable to that of gasoline. I'm not so sure about that. An article I found many many years ago, published in 2002, discusses such things. If the information in the article is correct, it is extremely difficult to beat gasoline for energy density. It lists gasoline as having an energy density of 9000Wh/l (watt-hours per liter). 150 bar H2 is only 405 Wh/l. Liquid H2 is 2600 Wh/l. Lithium batteries are listed as 250 Wh/l, but mind you this was published 12 years ago. Battery technology has made large leaps since then. Even if they've only doubled in energy density since then, that would still beat 150 bar H2. http://www.tinaja.com/glib/energfun.pdf Brian Hello Brian, Thanks for your interest in this topic. ================================================== =================== https://groups.google.com/forum/#!msg/rec.aviation.piloting/waXuA0ZesY0/-K1Cu9UddtgJ Path: g2news1.google.com!news2.google.com!border1.nntp.d ca.giganews.com!nntp.giganews.com!wn13feed!worldne t.att.net!bgtnsc05-news.ops.worldnet.att.net.POSTED!6dc4eacb!not-for-mail From: Larry Dighera Newsgroups: rec.aviation.piloting Subject: Electric Motorglider Flies Message-ID: References: X-Newsreader: Forte Agent 4.2/32.1118 trialware MIME-Version: 1.0 Content-Type: text/plain; charset=ISO-8859-1 Content-Transfer-Encoding: 8bit Lines: 117 NNTP-Posting-Host: b494a6c3070f7ceb3a376504e0d8f4e6 X-Complaints-To: X-Trace: bgtnsc05-news.ops.worldnet.att.net 1208280002 b494a6c3070f7ceb3a376504e0d8f4e6 (Tue, 15 Apr 2008 17:20:02 GMT) NNTP-Posting-Date: Tue, 15 Apr 2008 17:20:02 GMT Organization: AT&T Worldnet Date: Tue, 15 Apr 2008 17:20:02 GMT Xref: g2news1.google.com rec.aviation.piloting:186246 On Tue, 15 Apr 2008 01:05:04 GMT, wrote in : Despite the fact that electric motors must use iron/steel in their construction, they are significantly lighter (50%) than their internal combustion counterparts. But when the wiring, controls, batteries and perhaps fuel-cells are considered, I would guess the weight of an electrically powered aircraft would be roughly comparable to one powered by an internal combustion engine. So, with significantly less power/energy density than gasoline, batteries will not provide the same range/duration until they are improved further. But it is encouraging to see progress being made at last. Not going to happen. I hesitate to attempt to infer your meaning in that phrase, but if you mean Li-ion batteries, perhaps. If you're referring to electrically powered aircraft, they have already happened, and development is progressing. Energy densities fuel MJ/kg MJ/L JET-A 43 33 ethenol 30 24 Li-ion battery (projected) 1 2 NiMH battery .2 .4 ultracapacitor .02 .05 Regenerative fuel cell come in a bit under 2 MJ/kg. http://en.wikipedia.org/wiki/Energy_density Thank you for the factual data. It's interesting that gasoline is omitted: http://hypertextbook.com/facts/2003/ArthurGolnik.shtml Liquid Fuel MJ/litre litre/Tonne GJ/Tonne MJ/kg Gasoline, aviation 33.0 1412 49.6 36.4 Here's a little more data on Li-ion cells: http://en.wikipedia.org/wiki/Lithium_ion_battery Specific energy density: 150 to 200 Wh/kg (540 to 720 kJ/kg) Volumetric energy density: 250 to 530 Wh/l (900 to 1900 J/cm³) Specific power density: 300 to 1500 W/kg (@ 20 seconds and 285 Wh/l) There's a great comparison chart of energy densities he http://en.wikipedia.org/wiki/Energy_density Here are a few of the entries: Storage Type Energy Density By Mass (MJ/kg) ================================================== ================ lead acid battery 0.090.09?0.11[36]sm=n lithium ion battery-present capability 0.230.23?0.28 lithium ion battery-predicted future capability 0.540.54?0.9sm=n Regenerative Fuel Cell (fuel cell with internal Hydrogen reservoir used much as a battery) 1.62 Lithium ion battery with nanowires 2.54-2.72 TNT 4.184 dry cowdung and cameldung 15.5 calcium (burned in air) 15.9 PET pop bottle plastic 23.5?23.5 ethanol 30 aluminum (burned in air) 31.0 Jet A aviation fuel 42.8 gasoline 46.9 compressed natural gas at 200 bar (2,900.8 psi) 53.6 compressed hydrogen gas at 700 bar (10,423.5054 psi) 143 Enriched uranium (3.5% U235) in light water reactor 3,456,000 nuclear fission (of U-235) (Used in nuclear power plants) 88,250,000 From the data in the chart it would appear that a best-case Lithium ion battery with nanowires (2.54-2.72 MJ/kg) that would provide the equivalent energy of a given amount of gasoline (46.9 MJ/kg) would weigh 17.24 times as much as the gasoline it replaces. That doesn't look too terribly feasible for aviation use. Oh well.... However, hydrogen gas compressed to a pressure of ~10,500 psi (143 MJ/kg) would only weigh ~1/3 as much as the equivalent gasoline energy it replaces. If that hydrogen were used along with atmospheric oxygen to produce electricity by a fuel-cell with a typical efficiency of ~36% http://en.wikipedia.org/wiki/Fuel_cell#Efficiency, and the efficiency of the electrical motor, wiring, and controller were 90%, and the weights of the total systems were roughly equivalent, it would appear that there would be a close approximation of performance of today's aircraft including waste heat, but not noxious emissions nor noise. I'm not sure exactly how the overall efficiency would be affected by the use of pressurized oxygen, or if both the hydrogen and oxygen were produced by the electrolysis of water by photovoltaics. (Now, if the compressed hydrogen were carried in a tubular wing spar, imagine it's rigidity... /dream mode) Of course these rough theoretical calculations are predicated on existing technologies, and don't consider the inevitable future technical advancements. Thank you for providing the catalyst that led to this insight into the issue. Electricity is great stuff, but damn awkward to carry around. So it appears. ================================================== =================== |
AGM Batteries | Dave Anderer | Owning | 13 | March 29th 08 07:38 PM |
A350 XWB aims to rival the Boeing 787 Dreamliner | Larry Dighera | Piloting | 3 | November 17th 07 12:31 AM |
2-Batteries | [email protected] | Soaring | 69 | January 4th 07 04:09 AM |
160 new batteries | Mal | Soaring | 0 | October 27th 06 11:36 AM |
EADS aims at USAF tanker market | Matt Wiser | Military Aviation | 0 | September 20th 03 05:54 PM |
