#31
At 19:03 07 December 2014, Dave Nadler wrote:
On Sunday, December 7, 2014 1:56:25 PM UTC-5, wrote: Looking at my decade old code for a transducer based variometer, I see that I went to a bit of trouble to convert pressure to ISA altitude before differentiating to get rate of climb. Good, but its much easier just to correct by one_over_sigma ;-) For even more amusement, consider the relationships between "altitude corrected" rate of climb, IAS, TAS, calculated total energy compensation, and speed to fly... Right, proper instruments consider MC as a 'true' input as well as correcting vario, IAS-TAS, and of course polar. Discuss amongst yourselves ;-) Seems to me that this discussion is about a complete non problem. When we "read" a vario we are not really interested in the arbitrary figure it displays but more in the fact of whether the value is higher or lower than the previous value. In other words if 4kts is really 2kts at 10,000 ft it does not matter a jot to us. What does matter is that 4kts will always be greater than 2kts. We search for better lift not some arbitrary figure. |
#32
On Sunday, December 7, 2014 12:00:08 PM UTC-8, Dan Marotta wrote:
...And it's not even officially winter yet... Well, it's raining here in northern California, I can't even work on our winch 8^( OK, I understand about correcting the transducer based altitude, corrected for ISA, so I guess you're using your static and OAT inputs to calculate altitude before calculating and displaying the rate of change. Actually, OAT isn't used to convert pressure to ISA altitude, as what matters is the mean temperature of the column of air between your altitude and sea level, not OAT at that altitude. So, one would need to drop periodic sounding probes to correct for "true" altitude, but just applying a basic mapping from pressure to ISA altitude (or one_over_sigma as Dave indicated) is "good enough" for our purposes (if one wants to know the actual altitude, as such, applying a QNH or QFF setting gets you closer, yet). Likewise, for a transducer variometer hooked to a TE probe, static pressure is typically not used, instead one ends up with effectively "total energy altitude" (where you would end up if you could convert all (?) of your airspeed to altitude), which is again "good enough". So am I to understand, then, that my mechanical vario is displaying *indicated* rate of lift/sink while my electronic vario is displaying *true* rate of lift/sink? I guess I'll take a close look on my next wave flight. I think it may be a bit more complicated than that, but I've never really thought about what a mechanical flow-based variometer actually measures... Marc |
#33
On Sunday, December 7, 2014 3:30:05 PM UTC-5, Don Johnstone wrote:
Seems to me that this discussion is about a complete non problem. When we "read" a vario we are not really interested in the arbitrary figure it displays but more in the fact of whether the value is higher or lower than the previous value. In other words if 4kts is really 2kts at 10,000 ft it does not matter a jot to us. What does matter is that 4kts will always be greater than 2kts. We search for better lift not some arbitrary figure. No, it is important to know climb strength to accurately set speed-to-fly, MC or otherwise derived, for both inter-thermal cruise and final glide. All this is well-covered in Reichmann... |
#35
On Sunday, 7 December 2014 00:59:38 UTC+2, Dave Nadler wrote:
On Saturday, December 6, 2014 12:27:42 AM UTC-5, krasw wrote: ... variometer does not care about the absolute pressure. Really? What happens at 10,000 feet vs. sea level? Since the variometer flask contains same 10000 feet air, the speed of airflow trough variometer would be exactly same, in that sence it does not care. Depending on vario design, the force turning variometer vane could be less.. All of this (incl. temperature) is easily compensated in electric vario. Discuss amongst yourselves... Seems to me that you are participating this a lot, after all. |
#36
On Monday, December 8, 2014 5:01:59 AM UTC-5, krasw wrote:
On Sunday, 7 December 2014 00:59:38 UTC+2, Dave Nadler wrote: On Saturday, December 6, 2014 12:27:42 AM UTC-5, krasw wrote: ... variometer does not care about the absolute pressure. Really? What happens at 10,000 feet vs. sea level? Since the variometer flask contains same 10000 feet air... Really? Isn't the air less dense at 10,000 feet than at sea level?? Discuss amongst yourselves... |
#37
maanantai, 8. joulukuuta 2014 15.04.33 UTC+2 Dave Nadler kirjoitti:
On Monday, December 8, 2014 5:01:59 AM UTC-5, krasw wrote: On Sunday, 7 December 2014 00:59:38 UTC+2, Dave Nadler wrote: On Saturday, December 6, 2014 12:27:42 AM UTC-5, krasw wrote: ... variometer does not care about the absolute pressure. Really? What happens at 10,000 feet vs. sea level? Since the variometer flask contains same 10000 feet air... Really? Isn't the air less dense at 10,000 feet than at sea level?? Discuss amongst yourselves... Are you aware that you are clinging on a detail that is quite irrevelant when talking about the very basics of TE probe? What's next, shall we go trough air density vs. humidity relation? Isn't it annoying that every sentence I write is a question? |
#38
On Thursday, December 4, 2014 2:02:55 PM UTC-5, Jim Lewis wrote:
I have been trying to understand just how a TE probe functions. Hi Jim - I hope the RAS nonsense has not discouraged your quest for knowledge! Get yourself a copy of Helmut Reichmann's "Cross- Country Soaring". Instrumentation functions are covered in a practical and readable fashion, including of course TE probes. The book is also a fabulous overview of XC soaring basics. Enjoy! Best Regards, Dave PS: Beware answers you get on RAS! Way too many people happy to provide incomplete and/or incorrect answers with a solemn tone of authority... PPS: If you want to dig into the math, beware that early editions of Reichmann's book have the terms for some of the equations translated incorrectly (equations are correct but explanations of the terms are not). |
#39
On Wednesday, December 10, 2014 10:57:08 AM UTC-5, Dave Nadler wrote:
On Thursday, December 4, 2014 2:02:55 PM UTC-5, Jim Lewis wrote: I have been trying to understand just how a TE probe functions. Hi Jim - I hope the RAS nonsense has not discouraged your quest for knowledge! Get yourself a copy of Helmut Reichmann's "Cross- Country Soaring". Instrumentation functions are covered in a practical and readable fashion, including of course TE probes. The book is also a fabulous overview of XC soaring basics. Enjoy! Best Regards, Dave PS: Beware answers you get on RAS! Way too many people happy to provide incomplete and/or incorrect answers with a solemn tone of authority... PPS: If you want to dig into the math, beware that early editions of Reichmann's book have the terms for some of the equations translated incorrectly (equations are correct but explanations of the terms are not). Now you warn me! Today I replaced the venturi style TE probe with an ILEC fin mounted probe in fashionable blue anodized color. I measured thrice and cut once based on this thread's info. You guys better be right! Lane XF |
#40
Hi Dave,
I'm not at all discouraged! I've learned a lot and I think I now actually understand the TE system. I have Reichmann's books and many others too. Sometimes I'm too thick to understand what is being discussed but I keep trying. Thank you for your help. Jim |
TE probe? | [email protected] | Soaring | 12 | July 29th 14 03:54 AM |
TE probe up or down? | kirk.stant | Soaring | 25 | September 29th 10 07:48 PM |
Ka-6 TE Probe | vontresc | Soaring | 14 | August 30th 08 03:17 AM |
TE Probe on ASW-15 | [email protected] | Soaring | 4 | April 29th 07 01:43 AM |
TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 10:52 PM |
