On another note with flarmnet, when you register you need
to enter either your Flarm ID number OR your Hexadecimal from your aircraft. If you have a transponder you need to enter the Hexadecimal. For those with out transponder which do you enter? I think if you have no transponder you need to enter the Flarm ID instead of the Hexadecimal, but I have heard arguments for both sides and it appears a lot of pilots are unsure, would be nice if we all had this info entered correctly it is nice to see the glider ID of whoever is showing up on your Flarm screen. |
Hi Joe,
I recommend entering the Mode S ID - regardless of whether you have a transponder installed. I can't think of any reason not to. Every aircraft in the U.S. has a Mode S ID assigned. You can find them using the links in my PowerFLARM Tips document and at the top of my PowerFLARM page. http://www.cumulus-soaring.com/flarm.htm http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________________ "joesimmers" wrote in message ... On another note with flarmnet, when you register you need to enter either your Flarm ID number OR your Hexadecimal from your aircraft. If you have a transponder you need to enter the Hexadecimal. For those with out transponder which do you enter? I think if you have no transponder you need to enter the Flarm ID instead of the Hexadecimal, but I have heard arguments for both sides and it appears a lot of pilots are unsure, would be nice if we all had this info entered correctly it is nice to see the glider ID of whoever is showing up on your Flarm screen. |
(USA) FlarmNet usage | 2NO | Soaring | 15 | April 30th 13 11:58 AM |
PF Portable and Flarmnet | Andy[_1_] | Soaring | 0 | October 5th 12 02:55 PM |
FLARMnet file update | Andy[_1_] | Soaring | 1 | September 25th 12 06:59 PM |
FlarmNet | Brad[_2_] | Soaring | 6 | August 26th 12 06:35 PM |
DAFIF database to be removed from public domain | André Somers | Soaring | 2 | January 14th 05 04:10 PM |
