Winch Launch - Fatal
Old December 14th 16, 01:59 AM posted to rec.aviation.soaring
Default Winch Launch - Fatal
On Tuesday, December 6, 2016 at 7:15:05 AM UTC-7, Jock Proudfoot wrote:
You're right, relying on the pilot pulling the release doesn't work simply because it takes too long for the pilot to react.
I think there is just one cause of ground roll accidents and it's very simple - inadequate acceleration.
A glider just wants to fly and with the wing incidence angle at about 10 degrees with the tailwheel on the ground it will do so in about 2 seconds at 1G. Unless things are badly set up beforehand, the wings will stay balanced for at least that long. Once airborne. there is no risk of a ground roll accident.
The acceleration which worked with old wooden glider just doesn't get a heavy glass glider to aileron control speed and then airborne quickly enough.
Don, you brought up the old pitch-up myth so I'll go there.
Pitch-up on acceleration can only happen with the tailwheel in the air and that can only happen if the glider is slowly dragged into the air with feeble acceleration and THEN strong acceleration applied. It can't happen if strong acceleration is applied at the very start of the ground roll and maintained until the glider reaches the normal airspeed for rotating into the climb.
I could go on at length about this but I wrote a long paper on it available here https://dl.dropboxusercontent.com/u/...celeration.pdf Rather than take my word for it, I very strongly suggest the BGA and other national clubs do their own investigation using tension loggers. What you will see may terrify you.
Old December 14th 16, 09:35 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Hi Bill
An excellent paper and one that I will be sharing. It tallys with my own observations from watching multiple higher acceleration winch launches of a PW-5. In all cases the tail wheel hit the ground with the acceleration and with the stick neutral the glider lifted off in a shallow climb with a slow controlled rotation with increasing speed till it was in the full climb at around 150'
As described in your paper, the most dangerous winch launches I have seen and experienced have been ones with slow acceleration
Regards
Colin
Old December 14th 16, 08:43 PM posted to rec.aviation.soaring
B4soaring
ver
about 1
wing
n
doesn't get
quickl
enough
the ai
ai
It can'
groun
fo
available her
Rathe
othe
Wha
Hi Bil
th
til
hav
Regard
Coli
Ventus_a
The tailwheel hitting the ground is normal for all gliders that sit on
a nosewheel and happens because the CofG is higher than the
winch hook. It has nothing to do with the rate of acceleration.
Taking off into a shallow climb with the elevator neutral is what I
would call normal acceleration.
Bill's pdf shows something completely different. The pilot is holding
the stick too far back in the early stages of launch & the elevator is
pushing the tailwheel down on to the ground even after the
mainwheel has taken off. That's just poor technique & usually
happens because the pilot is behind the aircraft & blindly pulling
back after the glider starts moving.
Old December 14th 16, 09:19 AM posted to rec.aviation.soaring
Jim White[_3_]
and
feeb=
s=
main=
c=
limb.
available=
here
Rather
nationa=
se=
e may terrify you.
Hi Bill. If you follow URAS you will see that Don, whilst old and wise,
doesn't speak for the UK gliding community.
Old December 14th 16, 10:30 AM posted to rec.aviation.soaring
Terry Walsh[_2_]
and
feeb=
if
s=
main=
c=
limb.
available=
here
https://dl.dropboxusercontent.com/u/...cceleration.pd
Rather
other
nationa=
se=
e may terrify you.
Hi Bill,
The theory may be correct but I can assure you that a K18 ALWAYS needs the
application of almost full forward stck after lift off to prevent over
rotation. This is using a powerful V8 winch with about 2 seconds of ground
roll. Yes the accleration is still happening after lift off. With a narrow
steel drum throttle response is never instantaneous due to inertia of the
drum, even with the powerful (300 hp+) V8.
Old December 14th 16, 12:09 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
the ai
and
with
feeb=
happe
if
s=
and
main=
int
c=
limb.
available=
here
Rather
other
nationa=
you will
se=
e may terrify you.
wise
Hi Bill,
ALWAYS needs th
of groun
narro
of th
I believe there is a solution to this, one which no one will like, but
which would reduce the frequency of the accidents, unfortunately it
may also very expensive and difficult to achieve on existing aircraft
and would result in a reduction in winch launch height. Move the
launch hook forward.
Old December 15th 16, 10:12 AM posted to rec.aviation.soaring
David Salmon[_3_]
the ai
and
with
feeb=
happe
if
s=
and
main=
int
c=
limb.
available=
here
Rather
other
nationa=
you will
se=
e may terrify you.
wise
Hi Bill,
ALWAYS needs th
of groun
narro
of th
I've picked this one up rather late, and probably like Don, I have many
thousands of winch launches, in vintage gliders, modern gliders, gliders
with compromise hooks, and with C of G hooks, initially on Tost, not
exactly underpowered, and for the last 20 years on Skylaunch, certainly not
underpowered.
To comment on something Bill said, I have analysed quite a few, from 1 sec
logger traces (perhaps not the most accurate way, but all I've got), and
find initial acceleration to be nearer .6g/.7g, rather than 1g. Tost weak
links are approximately 1.3 times auw, so should take 1g , at least when
new.
The problem with the wing going down is I think, that the pilot can be
unaware. A long time ago I had a 19m Jantar, with a compromise well forward
hook, and a loop of cord attached to the release toggle, because you could
not reach it. One day I took a launch, when I got back a few hours later, a
fellow instructor asked if I knew that the wing had gone down, so hard that
everyone at the launch point turned to look. I probably had 1500 hours on
that glider alone, and quite a few hundred launches in it, but hadn't a
clue anything had happened. To me it was a normal launch, and I got away
with it.
I totally agree though that high acceleration is good, the opposite is not.
Again, years ago, probably in the Jantar again, I had a very slow ground
run, but got away. When I got back, I found that a subsequent launch in an
ASW27, had had a wing down accident, substantial damage, fortunately no
injury. Though not there to see it, I always put that down to a slow ground
run like mine.
Most of the early Schleicher gliders, K8, K18, K6, do need a forward stick
position at the start, unlike most others, when neutral is best. The glider
will aviate when ready, it doesn't need encouraging by the pilot.
Winch launching is not inherently dangerous, any more than walking down the
street is dangerous, unless something goes wrong. Not sure without checking
how many are done in the UK each year without incident, but it runs into
hundreds of thousands. Just a very few go wrong.
What I would like to see is a re-think on launch speeds. High speed is
safe, low speed is not. Yet we have ridiculous situations like the Puchacz,
which I think is otherwise the best training glider available, with a
maximum of 59 kts, yet not really safe on a winch launch below 55 kts. This
is a fully aerobatic, inverted flight glider!!!
With the Skylaunch, perhaps others, the throttle stop is set to suit the
wind and the glider. The driver then advances the throttle lever to that
stop over a second or two. I would like to see a completely computerised
system, whereby the wind profile and the glider are selected, and the
driver just presses a button to launch, and all the parameters are built
in, including initial acceleration, surely not that difficult with modern
technology. Obviously there must be a dead man's handle.
Dave
Old December 14th 16, 01:04 PM posted to rec.aviation.soaring
It is pointless to enter into any sort of winch launching discussion here that is based on decades of experience by thousands of European pilots.
Winch Launch School Karl Striedieck[_2_] Soaring 1 January 7th 16 03:10 PM
Winch Launch Fatality Nyal Williams[_2_] Soaring 89 June 27th 09 08:45 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
