Task turn angles other than 180 degrees, when is it safe?
Old December 17th 16, 04:00 AM posted to rec.aviation.soaring
Tim Taylor
Default Task turn angles other than 180 degrees, when is it safe?
I agree with Don. I prefer to keep all turns at least 60 degrees. 45 should be the absolute minimum and should only be used as a last resort. The bigger the turn area the greater the angle should be. The scariest I have ever flown was a big ring at Uvalde with a cloudstreet that bisected the turn area. Everyone lined up on the street and flew it in and out. Nothing like 45 gliders at cloudbase at 110 knots flying out and back on one street. This was pre-Flarm and I was afraid to pull up because of the loss of forward visibility. The midair at Uvalde was event that really made most tasking committees realize that nearly 180 degree (0 degree) turns must be avoided.
Flaps 40 Degrees Ken Kose General Aviation 3 February 14th 09 01:10 AM
VOR off by 30 degrees EK Owning 5 July 11th 08 06:51 PM
Angles Maple1 Aviation Photos 2 August 22nd 07 07:16 PM
Flap angles DeltaDeltaDelta Piloting 34 May 18th 04 12:09 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
