Correct adhesive to use to attach tail wheel assembly.
Old April 3rd 18, 10:24 PM posted to rec.aviation.soaring
Dan Marotta
Default Correct adhesive to use to attach tail wheel assembly.
30 years ago?
I think the entire fuselage of my 1985 LS-6a was fiber glass and it had
a break away tail skid from the factory and was modified with a roller
blade wheel later on.Â* My 2001 LAK-17a was all carbon and had a genuine
pneumatic wheel.Â* I was happier with the inflatable tire since it
provided better directional stability on takeoff and landing, didn't dig
in to the grass, and it never ripped off.
On 4/3/2018 9:27 AM, Jonathan St. Cloud wrote:
On Tuesday, April 3, 2018 at 7:23:49 AM UTC-7, Dan Marotta wrote:
Interesting point, but maybe they didn't make the tail booms as strong
30 years ago...
On 4/2/2018 9:21 PM, wrote:
The 3M heavy duty double sided tape does the job. It’s marketed as mailbox tape or something like that.
If that won’t work, 5 minute epoxy will. Yes, I hear all the cries about broken tail booms, but they haven’t made gliders with those “shear off” tail skids in 30 years so it can’t be that big of a deal.
Contact cement is the way to go if you enjoy wandering around in a huge grass field looking for your tail skid.
That’s my 2 cents, having tried all of these methods.
Dan, 5J
I know the Schleicher booms are strong, they are laid up with carbon and two layers of Kevlar.
Dan, 5J
Correct adhesive to use to attach tail wheel assembly. Tony[_5_] Soaring 7 April 3rd 18 03:05 AM
Correct adhesive to use to attach tail wheel assembly. Colin Roney Soaring 0 April 1st 18 08:37 AM
Correct adhesive to use to attach tail wheel assembly. Cookie Soaring 0 April 1st 18 05:49 AM
Correct adhesive to use to attach tail wheel assembly. NG[_2_] Soaring 0 April 1st 18 03:36 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
