On my Cirrus I've used Wildwood Contact Cement which comes in a can at Ace Hardware and others. So far so good
On Saturday, March 31, 2018 at 9:01:38 PM UTC-5, Tony wrote:
On my Cirrus I've used Wildwood Contact Cement which comes in a can at Ace Hardware and others. So far so good ditto on what Tony recommended, brushable though, not spray. Good luck, Scott. |
Standard application is with liquid contact cement. Be sure to give each side time to set-up before putting them together. Secondary method is a thick double sided tape. K&G used to carry it. I have never seen it other than glider suppy dealers in the US.
The skids are designed to break loose under load to protect the boom. Be careful not to use too strong of glue to attach it on. |
On Saturday, March 31, 2018 at 10:41:05 PM UTC-4, Tim Taylor wrote:
Standard application is with liquid contact cement. Be sure to give each side time to set-up before putting them together. Secondary method is a thick double sided tape. K&G used to carry it. I have never seen it other than glider suppy dealers in the US. The skids are designed to break loose under load to protect the boom. Be careful not to use too strong of glue to attach it on. Adding a wrap of fabric tape around the seam after curing seems to help prevent the start of peeling of the glue joint. UH |
On Sunday, April 1, 2018 at 7:48:06 AM UTC-5, wrote:
On Saturday, March 31, 2018 at 10:41:05 PM UTC-4, Tim Taylor wrote: Standard application is with liquid contact cement. Be sure to give each side time to set-up before putting them together. Secondary method is a thick double sided tape. K&G used to carry it. I have never seen it other than glider suppy dealers in the US. The skids are designed to break loose under load to protect the boom. Be careful not to use too strong of glue to attach it on. Adding a wrap of fabric tape around the seam after curing seems to help prevent the start of peeling of the glue joint. UH |
On Saturday, March 31, 2018 at 10:01:38 PM UTC-4, Tony wrote:
On my Cirrus I've used Wildwood Contact Cement which comes in a can at Ace Hardware and others. So far so good Weld Wood...Wildwood is a resort in NJ |
Weldwood - me, too.Â* On my ASW-19b and LS-6a.Â* Works like a charm. Apply
with a brush, allow to dry, then bring the parts together.Â* Be careful with alignment because it sticks! On 3/31/2018 8:01 PM, Tony wrote: On my Cirrus I've used Wildwood Contact Cement which comes in a can at Ace Hardware and others. So far so good -- Dan, 5J |
On Sunday, April 1, 2018 at 10:19:49 AM UTC-5, Dan Marotta wrote:
Weldwood - me, too.Â* On my ASW-19b and LS-6a.Â* Works like a charm. Apply with a brush, allow to dry, then bring the parts together.Â* Be careful with alignment because it sticks! On 3/31/2018 8:01 PM, Tony wrote: On my Cirrus I've used Wildwood Contact Cement which comes in a can at Ace Hardware and others. So far so good -- Dan, 5J Thanks to all for the replies. Whine, be helpless and the soaring community responds. A buddy left some weldwood and a couple of brushes in my hangar. Thanks Jim. I am currently out of dry Italian Red wine. If you have any suggestions, please deliver to my hangar. 9P |
ASW 19 tail wheel | [email protected] | Soaring | 13 | September 20th 16 11:09 PM |
spare tail dolly wheel assembly | [email protected] | Soaring | 3 | February 19th 15 02:29 PM |
ASW tail wheel | Dan Mockler | Soaring | 8 | July 31st 12 05:26 PM |
ASW tail wheel | Dan Mockler | Soaring | 0 | July 28th 12 09:53 PM |
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly | Tim Hanke | Soaring | 0 | February 8th 05 01:34 PM |
