Tapered pins (again)
Old April 27th 18, 08:45 PM posted to rec.aviation.soaring
Default Tapered pins (again)
I picked up this level for $30 yesterday and have not had an opportunity to test it while rigging, but my thought was to zero the level on fuselage and then determine the appropriate angle for the wings when each was at the correct dihedral for assembly.
https://m.lowes.com/pd/Johnson-Level...tor/1000085673
Old April 27th 18, 10:24 PM posted to rec.aviation.soaring
bumper[_4_]
Better than a broom handle, and no need to cut up a wood bat, go on-line and search for wood tire thumper.
Note: These may also be useful for thumping other things, both animate (to get their attention) or inanimate (for the same reason).
bumper
Old April 28th 18, 03:06 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
I had a machinist make tapered inserts for the 27 pins. The pin is hollow and was heated before the cooled,tapered insert was inserted.
As noted, as built there is practically no pin protruding beyond the spar when inserted and not much space between the pin end and the fuselage spar box. A small amount of Dremel action on a non load-bearing part of the spar box allows enough room for the lightly longer, tapered pin.
The pin handle is removed (four screws) before the pin is chucked in a lathe and the blunt tip cut away.
As delivered, the relatively blunt end of the original pins require precise alignment for pin insertion, but with the tapered ends they can be shoved in with only casual attention to alignment.
This solution eliminates extra gizmos such as pry bars, shovel handles or nylon tools.
Anyone interested in pics of the pins and spar box grinding can get same from: karls at uplink.net
Oudie DB9 pins to Powerflarm Ken Sorenson Soaring 2 August 25th 15 09:49 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
Tapered Wings and North-Paw Saws [email protected] Home Built 5 April 8th 06 08:41 PM
Tapered Rod Gear Leg Source Dick Home Built 3 January 13th 04 10:10 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
