Call to HP14 owners
Old August 6th 18, 02:48 AM posted to rec.aviation.soaring
Blue Whale
Default Call to HP14 owners
Is Wayne still actively maintaining the site? I haven't seen any new postings for quite some time.
Old August 6th 18, 02:55 AM posted to rec.aviation.soaring
AS
Not sure about that but I joined that group not too long ago to follow the development of the jet-powered HP glider.
Uli
'AS'
Old August 6th 18, 02:07 PM posted to rec.aviation.soaring
Uli the hp group looks to be pretty inactive. But as to the jet power adaptations, have you seen the 1-26 conversion that the Sanders did? I looked it over at the convention this year and talked extensively to old man Sanders (who I already knew from the war bird circles) and his son who did the engineering. It is remarkably simple and wonderfully engineered and mostly consists of off-the-shelf items.
Dan
Old August 6th 18, 04:26 AM posted to rec.aviation.soaring
Frank Whiteley
Yes, I messaged Wayne. He says there was a 5pm request (Idaho). So Dan should be in the group now.
Old August 6th 18, 06:09 AM posted to rec.aviation.soaring
Hello all , might not be the right place here , but I am also looking for some help. my name is also Uli so you might call me Ulrich to not getting mixed up . I bought the RHJ 8 from Graham Brown 2 years ago and would like to get it in the air some time . I had one flight in it when picking up in Ottawa . it needs basically only a new paint job on the wings . So if anybody can give me some advise how to proceed with that job .I was planning to use paint stripper . As well I try to figure out where best to place a centre of gravity hook ? The doubleseater got the belly hook removed some time in live and I havent been able to track down where the location was . I want to do winch launching with it.
Old August 6th 18, 02:13 PM posted to rec.aviation.soaring
I am looking at the same job as Ulrich in having to strip wings and fuselage. Instead of stripping I am looking at using my soda blaster as it will strip the paint while hopefully not remove the underlying contouring which appears to be still good.
I have used the soda blaster before for the gentle non destructive stripping of many aluminum parts but not on parts with bondo/microballon bases, anyone here have any experience in this?
Dan
Old August 6th 18, 05:45 PM posted to rec.aviation.soaring
Dan
I looked into soda blasting ,too , for the same reason not to remove any bondo. But have no experience with either methode . My friends in my German gliding club say there stripper don't remove bondo and just a week ago I met here in Whitehorse somebody who repainted DC 3 s and he confirmed that . He said if it would weaken the bondo you simply put a layer of epoxy paint over that aerea in question before repainting . Also I don't think on my wings is a lot of bondo other than over the rivets . About soda blasting I heared it is a very slow process and you use a lot of soda ?
Old August 6th 18, 07:31 PM posted to rec.aviation.soaring
AS
Dan
I looked into soda blasting ,too , for the same reason not to remove any bondo. But have no experience with either methode . My friends in my German gliding club say there stripper don't remove bondo and just a week ago I met here in Whitehorse somebody who repainted DC 3 s and he confirmed that .. He said if it would weaken the bondo you simply put a layer of epoxy paint over that aerea in question before repainting . Also I don't think on my wings is a lot of bondo other than over the rivets . About soda blasting I heared it is a very slow process and you use a lot of soda ?
Hallo Ulrich
could that be an alternative to soda-blasting?
https://www.youtube.com/watch?v=mLDQP1XA2_4&t=4s
Not sure where one would get one of these flash lamps but it sure looks like a cool process for metal gliders.
Uli
'AS'
Old August 7th 18, 02:58 AM posted to rec.aviation.soaring
Dan
Hallo Ulrich
Uli
'AS'
It probably is but looks like complicated to set up to me.
HP14 [email protected] Soaring 16 January 26th 17 09:23 PM
Beech Duke Owners/ex-Owners ple help... Stanley Owning 12 June 10th 16 12:36 AM
DG-300/303 owners... Alan Montague Soaring 48 April 22nd 07 01:58 AM
DG-300/303 owners... Alan Montague Soaring 0 April 16th 07 05:37 PM
Call to all SA Trailer owners (US Make) [email protected] Soaring 0 December 16th 06 05:37 AM
