IGC to replace FLARM ? ?
Old November 11th 18, 03:24 PM posted to rec.aviation.soaring
Default IGC to replace FLARM ? ?
"Intention is to develop own fully secured tracking function with a
possibility of time delay."
It will be tricky to have open access to the hardware and software and also controlled, secure access to the tactical information.
I could see an open source/open hardware system with a mechanical seal protecting some internal private keys and the decryption engine that uses them.
Everybody would broadcast position protected by a public/private key pair. CD puts the private key required to decrypt along with an approved software load into a standard, sealable receiver engine.
It would be nice to allow the contestant to play with everything, but I think secure will require at least some small part of the receive engine to be sealed.
Old November 13th 18, 06:35 PM posted to rec.aviation.soaring
Everybody would broadcast position protected by a public/private key pair.. CD puts the private key required to decrypt along with an approved software load into a standard, sealable receiver engine.
My informed source says the time delay (10 minutes or so) would be used instead of encryption. The time delay can be built into the transmitter. Thus nothing in any receiver could foil it. There would not be an incentive for the pilot to change anything in their transmitter, unless they want to be leached on. I wonder though whether that would create an incentive to start 10 minutes after the best pilots?
Old November 13th 18, 06:42 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Isn't Europe, like the US, on track to require ADSB-out soon? You'll know instantly where everyone is within 100 miles, flarm or no flarm. Putting the knowing where people are genie back in the bottle seems like a hard task.
John Cochrane
Old November 14th 18, 04:06 AM posted to rec.aviation.soaring
kinsell
John Cochrane
Are you aware there's no 2020 mandate for gliders in the U.S.?
Old November 13th 18, 08:46 PM posted to rec.aviation.soaring
Why put in place a delayed tracking solution besides instant OGN tracking? This is pointless. FLARM is mandatory in contests. Anyone who is interested may use existing FLARM-based OGN tracking infrastructure and circumvent whatever time delay is implemented in separate transmitters.
Old November 14th 18, 06:29 AM posted to rec.aviation.soaring
krasw
You are right. As long as there is flarm in the glider it can be tracked real time from ground, no matter what. I guess using new tracking system would mean that pilots switch off their flarms in competitions. This is a problem that has so far only bad solutions.
Old November 13th 18, 09:45 PM posted to rec.aviation.soaring
Benedict Smith
with a
=20
software and
al=
=20
mechanical seal
pr=
that uses
the=
m.
=20
public/private key
pair=
approved
softw=
=20
everything, but I
t=
engine to
be sealed.
would be used
ins=
transmitter.
Thu=
incentive
f=
want to
b=
incentive to
st=
10 minute delay ? I thought the idea of FLARM was for safety,
perhaps they are they expecting messages such as:
“there was a glider 2 miles out on a collision course 10 minutes
ago, the fact that you are reading this message suggests that you
saw and avoided it without my help ! Have a nice day”
Sounds rather like something the late Douglas Adams would come
up with.
Old November 13th 18, 10:16 PM posted to rec.aviation.soaring
JS[_5_]
with a
=20
software and
al=
=20
mechanical seal
pr=
that uses
the=
m.
=20
public/private key
pair=
approved
softw=
=20
everything, but I
t=
engine to
be sealed.
would be used
ins=
transmitter.
Thu=
incentive
f=
want to
b=
incentive to
st=
up with.
Aren't we confusing tracking capability with collision avoidance capability?
This appears to be a move to build a new "live" tracking mechanism. Latency is an option often used for contest tracking.
Old November 14th 18, 07:46 AM posted to rec.aviation.soaring
Such live tracking systems based on collision avoidance techology already exist for quite a while (Flightradar24, OGN). Since 2017 FLARM based OGN has been used more or less as the standard tracking tool on competitions in Europe. It has to be made sure that collision avoidance is not reduced due to this 2nd nature of FLARM.
Old November 14th 18, 09:27 AM posted to rec.aviation.soaring
Jim White[_3_]
ADSB is not mandated in Europe. The CAA wanted to mandate SSR in UK but
this was sent down pending the development of low cost / low power ADSB.
This is now available from Uavionics at about £400. At that price I expect
a wide take up in the UK. Why wouldn't you want to know about spam cans,
CAT, drones, and helicopters as well as gliders and why would you want to
hide from ATC??
So in practice the rule makers for gliding competition cannot ban
conspicuity / situational awareness tools from the cockpit as this would
compromise safety. The genie is well and truly out of the bottle. As it was
with GPS etc.
It is possible to slow him down though. You write the rule that no data
(nor voice) is allowed from ground to cockpit and no data other than
required for SA / safety between pilots.
Yes, this is virtually impossible to police but if the penalty was a 5 year
ban from competition, it may still work.
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
IFR GPS replace DME / ADF? [email protected] Instrument Flight Rules 21 May 15th 06 03:13 PM
