I have a portable FLARM that I may need to install in a loaner glider. Installation will be awkward but could be much better if I use an external display that I have surplus from my brick installs.
Has any one done this and can you advise how it worked out? Thanks UH |
Yes you can connect any external display to the portable the same way you would connect to the core.
We just did this in our club ship, connected a portable to LXNAV S8 (which is also a powerflarm display). The portable is acting as both GPS source and Flarm source. Ramy |
But where do you stash the portable and how do you access it to turn it
on/off?Â* I assume you can control display range from whatever display you're using. When I first got a portable, I fashioned an aluminum plate the size of the unit with an extension in the back center.Â* I used that extension to fasten the whole contraption to the top center of the glare shield (the Stemme has 4 screws holding the glare shield on and one of them is top center front.Â* Later, when I decided to keep the unit, I drilled two holes in the glare shield for mounting screws from below. My ClearNav display provides the best pictorial information but the PF display is still useful sometimes. On 4/29/2019 12:19 AM, Ramy wrote: Yes you can connect any external display to the portable the same way you would connect to the core. We just did this in our club ship, connected a portable to LXNAV S8 (which is also a powerflarm display). The portable is acting as both GPS source and Flarm source. Ramy -- Dan, 5J |
Indeed the portable needs to be turned on, which requires pressing the button twice. I wish it would have turned on automatically with external power like core does. I wonder if this could be a firmware fix?
Ramy |
Flat external FLARM antenna? | Matt Herron Jr. | Soaring | 22 | May 11th 18 09:10 PM |
PowerFLARM core external display software update | kirk.stant | Soaring | 5 | January 28th 13 08:56 PM |
Q: Position of external Flarm RF antenna on tow plane Aviat Husky A1 | RuudH | Soaring | 5 | December 20th 12 04:58 PM |
Butterfly external display questions | Andy[_1_] | Soaring | 30 | October 15th 12 07:20 AM |
Best PDA/PNA for FLARM display? | Frank Paynter[_2_] | Soaring | 14 | August 28th 11 09:24 AM |
