Tom,
Airspace files published in connection with contests document (exactly) the airspace that is closed to the contest. "SSA Modifications" means that the airspace vertical limits have been modified in accordance with the practice that "Airspace above closed airspace is closed to the contest". For example, the ceiling for Blass B airspace will be extended to FL180. Again note that the reason for publishing contest airspace files is to document what airspace is closed to the contest. It is entirely possible that airspace included in files from Soaringdata.info would be missing from the contest file. For example, if there is a nearby MOA or Parachute Jump Area that the contest committee elects to keep open to the contest, that would be missing from the contest airspace file. Lynn Alley "2KA" |
Thanks for the excellent explanation Lynn and thank you for providing the on-line resources!
Note that the complete airspace file for the contest is also available, to provide you with the full picture.
John L |
using airspace files on XCSOAR/ Kobo | firsys | Soaring | 1 | April 27th 16 06:00 PM |
Oudie 2 airspace files | 2G | Soaring | 4 | July 1st 14 08:08 PM |
US-Canada airspace/border files available | Tuno | Soaring | 2 | April 3rd 10 11:25 PM |
(USA) Soaring airspace files from NFD -- now available | Tuno | Soaring | 11 | December 23rd 07 04:15 PM |
Load airspace files into emap | Jon Marshall | Soaring | 0 | August 14th 05 08:56 AM |
