Rogue IFR
Old October 28th 03, 10:57 PM
Ron Natalie
"Judah" wrote in message ...
Not if he's operating VFR. There are no clearances for entry of Class
D airspace by VFR aircraft in the US.
What about a transition clearance?
There ain't no such thing.
  #122
Old October 28th 03, 11:55 PM
Judah
I stand corrected... Two-way radio communications must be established, but
a "clearance" is not required.
Somehow the difference momentarily eluded me... After all, if an ATC
authority can deny you the privilege of entering his/her airspace (either
by requesting that you "Remain Clear the Class Delta", or by not
acknowledging your tail number), it implies he is implicitly clearing you
into his airspace when acknowledging your tail number and not restricting
you from his airspace.
That said, technically speaking, you are correct. There is no VFR clearance
into Class D...
"Steven P. McNicoll" wrote in
ink.net:
It does not exist.
  #123
Old October 29th 03, 05:25 PM
Corky Scott
On Tue, 28 Oct 2003 17:57:43 -0500, "Ron Natalie"
So when the guys in the choppers call up Lebanon tower up here in NH
and request clearance through the class D airspace, they're just being
thoughtful?
Without that call, they'd be cruising through the traffic pattern at
500 feet unannounced. That's straight over the runways. It happens
fairly regularly, and they call in and ask permission every time.
What am I missing?
Corky Scott
  #124
Old October 29th 03, 06:02 PM
Ron Natalie
"Corky Scott" wrote in message ...
thoughtful?
Nope, they're just using the wrong terms. All you need to do wo enter the
class D airspace is this:
27K: Lebanon Tower, Navion 5327K
TWR: Navion 5327K, LebanonTower
What am I missing?
You're missing that it is not a clearance. All you need to be is in communication
with them. While it's generally accepted procedure to tell the tower what you're
doing, you're not asking their permission. If they need you to do otherwise, they
can instruct you.
  #125
Old October 29th 03, 08:42 PM
Steven P. McNicoll
A clearance is an authorization by air traffic control, for the purpose of
preventing collision between known aircraft, for an aircraft to proceed
under specified traffic conditions within controlled airspace. Clearances,
for the most part, imply separation. ATC does not separate VFR aircraft in
Class D airspace so a clearance is not required.
  #126
Old October 29th 03, 08:44 PM
Steven P. McNicoll
thoughtful?
No, they're just misusing the word "clearance".
  #128
Old October 29th 03, 11:54 PM
G.R. Patterson III
Ron Natalie wrote:
If they need you to do otherwise, they can instruct you.
And if they want you to stay out, they will refuse to answer you.
George Patterson
You can dress a hog in a tuxedo, but he still wants to roll in the mud.
  #129
Old October 30th 03, 12:04 AM
Steven P. McNicoll
"Peter Duniho" wrote in message
ATC doesn't have enroute radar capable of determining when another
aircraft is within those limits.
Enroute radar? Do you mean Air Route Surveillance Radar? Why are we
suddenly limited to ARSR for discussion purposes? Please, Pete, tell us
about the capabilities of ATC radar.
Furthermore, that assumes accurate reporting by the VFR target's
transponder. Again, an unidentified target would not qualify for
that assumption.
It assumes nothing at all. If a pilot reports he's in the clouds, then any
other
aircraft that is within 2000 feet horizontally, 1000 feet above, or 500 feet
below
the reporting aircraft MUST be in IMC.
There was no such part.
Yes there was. You said ATC can't rely on PIREPs to KNOW something. That's
obviously incorrect.
  #130
Old October 30th 03, 12:29 AM
Peter Duniho
ink.net...
any
other aircraft that is within 2000 feet horizontally, 1000 feet above, or
500 feet below the reporting aircraft MUST be in IMC.
ATC has no way of knowing that the VFR target in question is within those
limits.
That's
Wow. With the "...about the VFR target" implied, your misunderstanding was
understandable, if a bit surprising. But with it being called out
explicitly to you, your ignorance is downright shocking.
Pete
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield Paul J. Adam Military Aviation 1 August 9th 04 08:29 PM
About when did a US/CCCP war become suicidal? james_anatidae Military Aviation 96 February 29th 04 03:24 PM
US plans 6,000mph bomber to hit rogue regimes from edge of space Otis Willie Military Aviation 14 August 5th 03 01:48 AM
Rogue State jukita Military Aviation 18 July 13th 03 02:22 PM
