Cobra trailer wiring diagram
Old April 18th 07, 02:53 PM posted to rec.aviation.soaring
Tuno
Default Cobra trailer wiring diagram
Dave, it's the latter, it came with a "7-way blade" which is round.
I'm the second owner and the first tells me he made no modifications.
However my on-site engineer (who goes by "Dad") sent me the following
report this morning:
snip
The problem I had this morning was with the 7/4-pin adapter. That
sucker did not have the common wire connected thru from the 4-pin plug
to the 7-pin plug. Ordinarily that should not be a problem PROVIDED
the trailer is physically hitched to the tow car--the system uses
chassis metal for the common return. But I did not have a physical
connection this morning, only the electrical connection. This evening,
when I jumpered the common lead through from the 4-pin to the 7-pin,
everything worked like the factory said it should (but not like that
wiring diagram you found on the net this morning). The upper (amber)
lamp is the turn signal, the middle (red) lamp is the brake, and the
lower (red) is the tail light.
So I made the change that Mac described. Removed the lead from the
brake lamp and taped it off. Switched the lead from the turn lamp to
the brake lamp (in the 4-pin system, that serves as both brake and
turn signal). Then I gave it a full test. Tail only, tail and turn,
brake only, brake and turn, and brake, tail, and turn. Everyting now
works like it should in a 4-pin setup with my van.
/snip
Thanks to everyone for the feedback on this topic. I'll be prepared
for the new trailer this summer!
2NO
Old April 18th 07, 03:01 PM posted to rec.aviation.soaring
Tuno
FYI: You can purchase a 7-to-4 pin adapter at auto
and RV supply stores. If you have a 7-pin female electrical
plug on your car, this will convert it to the American
4-pin plug on many trailers.
I use two tow vehicles -- a Toyota pickup for some weekends and an RV
for others. The pickup has both 7-way blade and 4-way flat. The RV has
6-way round (that's with one in the center). A problem I had (until
yesterday) was I could not find a 6-way to 7-way adapter, only 7-way
to 6-way (which of course are backwards gendered), so when pulling
with the RV I had to use a 6-to-4 and a 4-to-7, which looked like
something Rube Goldberg put together. As my engineer reported in my
earlier post, there was a problem with the 4-to-7 adapter. He fixed
that, and did the rewiring that Marc suggested, now everything works
-- with his van at least.
2NO
Wiring diagram for GA radio/mic? Gary G General Aviation 15 November 23rd 05 03:33 PM
Wiring diagram for mic? Gary G Home Built 5 November 3rd 05 03:21 PM
Wiring diagram for GA mic Gary G Piloting 0 November 2nd 05 01:15 PM
looking for Dittel FSG 60M wiring diagram ken ward Soaring 1 May 29th 05 02:54 AM
King KMA-26 Wiring Diagram Keith Dobbins General Aviation 0 August 23rd 03 04:03 AM
