Cobra trailer wiring diagram
Old April 17th 07, 05:10 PM posted to rec.aviation.soaring
Tuno
Default Cobra trailer wiring diagram
Is there a softcopy someone can send me? ... or any helpful reference?
The running lights on my 2002 Cobra work properly but I get strange
results with the turn signals, testing with three different tow
vehicles.
Are there any caveats I should be aware of in using 6-way-round to 4-
way-flat and 4-way-flat to 7-way-blade adapters for the trailer? (I've
never been able to find a 6-to-7 adapter. One of my tow vehicles is an
RV with 6-way round, and my trailer has 7-way blade. I've found 7-
to-6, but not 6-to-7, appropriately gendered.)
~ted/2NO
Old April 17th 07, 05:15 PM posted to rec.aviation.soaring
vehicles.
~ted/2NO
Click on "Engineering here":
http://www.cobratrailer.de/english/index.html
Best Regards, Dave
Old April 17th 07, 10:14 PM posted to rec.aviation.soaring
Tuno
Dave,
The Cobra site has diagrams for 7-pins and 13-points. My Cobra has a 7-
pin blade connector, which according to my on-site engineer says is
wired incorrectly compared to the diagram.
Has anyone changed the Cobra 7-pin setup to a 4-pin? My last Cobra
trailer had a 4-pin flat connector. I'm wondering if I should switch
it to that.
~ted/2NO
Old April 18th 07, 12:32 AM posted to rec.aviation.soaring
Tony Verhulst
it to that.
I have done that on my Komet trailer. See
http://home.comcast.net/~verhulst/SO...onversion.html
Tony V.
Old April 18th 07, 07:39 AM posted to rec.aviation.soaring
On Apr 17, 10:14 pm, Tuno wrote:
Dave,
it to that.
~ted/2NO
Ted - The Cobra trailer can be ordered with the European standard
connector (big round connector with big round pins), or a USA RV
common trailer connector (blade pins, round connector). Perhaps
yours is the latter ? Is this trailer as new or has it been rewired ?
See ya, Dave
Old April 18th 07, 02:53 PM posted to rec.aviation.soaring
Tuno
Dave, it's the latter, it came with a "7-way blade" which is round.
I'm the second owner and the first tells me he made no modifications.
However my on-site engineer (who goes by "Dad") sent me the following
report this morning:
snip
The problem I had this morning was with the 7/4-pin adapter. That
sucker did not have the common wire connected thru from the 4-pin plug
to the 7-pin plug. Ordinarily that should not be a problem PROVIDED
the trailer is physically hitched to the tow car--the system uses
chassis metal for the common return. But I did not have a physical
connection this morning, only the electrical connection. This evening,
when I jumpered the common lead through from the 4-pin to the 7-pin,
everything worked like the factory said it should (but not like that
wiring diagram you found on the net this morning). The upper (amber)
lamp is the turn signal, the middle (red) lamp is the brake, and the
lower (red) is the tail light.
So I made the change that Mac described. Removed the lead from the
brake lamp and taped it off. Switched the lead from the turn lamp to
the brake lamp (in the 4-pin system, that serves as both brake and
turn signal). Then I gave it a full test. Tail only, tail and turn,
brake only, brake and turn, and brake, tail, and turn. Everyting now
works like it should in a 4-pin setup with my van.
/snip
Thanks to everyone for the feedback on this topic. I'll be prepared
for the new trailer this summer!
2NO
Old April 17th 07, 06:30 PM posted to rec.aviation.soaring
Tim Mara
diagrams are on cobra website http://www.cobratrailer.de/english/index.html
tim
"Tuno" wrote in message
vehicles.
~ted/2NO
Old April 17th 07, 08:10 PM posted to rec.aviation.soaring
Mike[_8_]
Turn signals are blinking brake lights?
vehicles.
~ted/2NO
Old April 17th 07, 08:26 PM posted to rec.aviation.soaring
Marc Ramsey
Indeed, the first thing I do when I get hold of a Cobra trailer is take
the tail light covers off, and swap the leads (no cutting or soldering
required) for the turn and brake lights. As delivered, the brake lights
are on a common circuit, and the turn lights are amber, so you can't
get the 4-way "US standard trailer" combined red brake and turn signals
without doing this swap...
Marc
vehicles.
~ted/2NO
Wiring diagram for GA radio/mic? Gary G General Aviation 15 November 23rd 05 03:33 PM
Wiring diagram for mic? Gary G Home Built 5 November 3rd 05 03:21 PM
Wiring diagram for GA mic Gary G Piloting 0 November 2nd 05 01:15 PM
looking for Dittel FSG 60M wiring diagram ken ward Soaring 1 May 29th 05 02:54 AM
King KMA-26 Wiring Diagram Keith Dobbins General Aviation 0 August 23rd 03 04:03 AM
