#21
Steven P. McNicoll wrote:
Sam Spade wrote: In any case, my interptretation of when I am legally on top may differ from your's. The typical kee-jerk response is to "please the controller" and report on top when just breaking out in the clear. You're on top when you're in conditions suitable for VFR flight. You're not on top when you break out into the sunshine, you have to be at least 1000 feet above that cloud. My point exactly. |
Sam Spade wrote:
Terence Wilson wrote: On a few occasions I have filed a departure procedure to a nearby intersection just to get on top (comments section reads "IFR to VFR on top"). After breaking out of the clouds and advising ATC of the bases and tops, I usually cancel IFR and proceed "own nav" with flight following. Which brings me to my question, if I cancel inside Bravo airspace do I have an implicit clearance because I got there under IFR in the first place, or is it common practice for ATC to give an explicit clearance? I ask because I'm a new instrument rated pilot and I'm pretty sure both scenarios have happened to me recently. Thanks in advance. You have no idea of what ATC needs to do with you if you cancel on an IFR climnb to on-top. So, keep it simple, and stay with the IFR clearance until either above or otherwise clear of the Class B airspace. Hogwash. Cancelling IFR only makes ATC's life easier. Less separation is required. You do not need to prenegotiate....."Ah, approach, I'll cancel if you give me clearance out of the class B." |
![]() "Steven P. McNicoll" wrote in message m... Mark Hansen wrote: My gosh, Steven. The OP said he was canceling while inside Class B and you said he needed to be 1000' above the clouds. Now because you have been caught making a mistake, you must try to twist the discussion around to obfuscate the fact. I believe I said I might have lost track of the thread. This might be because no one believed it...a controller...lost track? Doesn't say a lot about competency. Regards, BobF. |
Bob F. wrote:
This might be because no one believed it...a controller...lost track? Doesn't say a lot about competency. You're free to believe whatever you choose. |
Any Recommendations for Noise Cancelling Headsets? | Google Madness | Piloting | 10 | April 1st 07 06:39 AM |
Any Recommendations for Noise Cancelling Headsets? | Google Madness | Piloting | 5 | March 30th 07 01:51 PM |
Bravo | Mal[_3_] | Aviation Photos | 0 | March 15th 07 02:47 AM |
Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 09:35 PM |
Lightspeed Headset mic noise cancelling performance | CharlieBuda | Piloting | 2 | December 22nd 06 07:54 PM |
