Cancelling IFR in Bravo airspace
Old August 7th 08, 02:58 AM posted to rec.aviation.ifr
Terence Wilson[_2_]
Default Cancelling IFR in Bravo airspace
On a few occasions I have filed a departure procedure to a nearby
intersection just to get on top (comments section reads "IFR to VFR on
top"). After breaking out of the clouds and advising ATC of the bases
and tops, I usually cancel IFR and proceed "own nav" with flight
following. Which brings me to my question, if I cancel inside Bravo
airspace do I have an implicit clearance because I got there under IFR
in the first place, or is it common practice for ATC to give an
explicit clearance?
I ask because I'm a new instrument rated pilot and I'm pretty sure
both scenarios have happened to me recently. Thanks in advance.
Old August 7th 08, 03:15 AM posted to rec.aviation.ifr
Sam Spade
explicit clearance?
You have no idea of what ATC needs to do with you if you cancel on an
IFR climnb to on-top. So, keep it simple, and stay with the IFR
clearance until either above or otherwise clear of the Class B airspace.
Old August 7th 08, 03:38 AM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
explicit clearance?
Is your clearance limit inside Class B airspace?
Old August 7th 08, 04:37 AM posted to rec.aviation.ifr
Terence Wilson[_2_]
On Wed, 06 Aug 2008 18:15:04 -0700, Sam Spade
On the last two occasions ATC has queried whether I was on top yet and
then asked what my intention was, I cancelled, and continued on my
merry way inside Bravo.
So obviously they were ok with it, but my original question stands, am
I cleared into the class B after I canel in class B?
Terence Wilson[_2_]
On Wed, 6 Aug 2008 20:38:48 -0500, "Steven P. McNicoll"
explicit clearance?
Outside.
Old August 7th 08, 05:27 AM posted to rec.aviation.ifr
Did you receive an ATC clearance from the ATC facility having jurisdiction
for that area before operating an aircraft in that area? Only one clearance
is required.
Old August 7th 08, 05:28 AM posted to rec.aviation.ifr
Outside.
Then I don't see the issue. If you're concerned about having a clearance to
operate in Class B airspace don't cancel IFR until you're outside.
Old August 7th 08, 06:03 AM posted to rec.aviation.ifr
Hamish Reid
explicit clearance?
Like me, by the sound of things Terence flies out of Oakland (KOAK) in
NorCal Approach territory (in 2BG, no less :-)). On the usual "get out
of Oakland" OTP clearance (e.g. vectors for REBAS or SGD), NorCal makes
it very clear they want you to cancel as soon as possible -- "advise
when clear of clouds" often followed by terse questions about whether
you've broken out on top or not -- and can get quite audibly irritated
if you don't cancel ASAP (as I discovered a while back :-)). Given the
traffic routing into and out of KOAK and KSFO in the vicinity of path
between KOAK and REBAS (for example), I guess I don't blame them -- and
you end up canceling inside the Class B airspace, typically somewhere
abeam Emeryville or Berkeley (or Hayward if you're going the other way).
At which point you typically get told to resume own nav, VFR, with
flight following.
Having said all that, I guess I've always assumed that if they cut me
loose like that deep in the Class B airspace they've at least implicitly
cleared me into that airspace already. But then in the last few years
NorCal has had a lot of trouble with the c word when it comes to KSFO's
Class B. I've approached or departed Oakland VFR many times and been
given an altitude assignment (for traffic or whatever) that puts me into
the Class B without hearing the magic "cleared into the Class B...".
It's been a common complaint 'round here for quite a while; yet NorCal
controllers tend to get irritated if you ask whether you've been cleared
into the Class B airspace...
Hamish
Old August 7th 08, 03:21 PM posted to rec.aviation.ifr
Sam Spade
If my clearance limit for the IFR climb was inside Class B I would
reply, "I request a clearance to outside Class B before I cancel."
It's your butt that's on the line, not their's.
Or, just say "negative" when they ask if you're on top, thus forcing a
clearance out of the quagmire.
Old August 7th 08, 05:01 PM posted to rec.aviation.ifr
Mark Hansen
I'm confused about why you believe you have to lie about being on top.
When asked for your intentions, why not just say "Remain IFR until
clear of Class Bravo"?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Any Recommendations for Noise Cancelling Headsets? Google Madness Piloting 10 April 1st 07 07:39 AM
Any Recommendations for Noise Cancelling Headsets? Google Madness Piloting 5 March 30th 07 02:51 PM
Bravo Mal[_3_] Aviation Photos 0 March 15th 07 03:47 AM
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 10:35 PM
Lightspeed Headset mic noise cancelling performance CharlieBuda Piloting 2 December 22nd 06 08:54 PM
