#71
Roy N5804F wrote:
Roger, I forgot to mention, that like yourself I am licensed radio amateur [W8/G4DYR] and have the in-depth technical understanding of the avionics fitted in the Archer. If asked a similar question by the DE, I too would probably head off down the full electronic technical path to describe how it worked :-) Is that called "trick the man who holds your family jewels in his hands" before the flight portion of the check ride? |
#72
1: Why should we not protect commercial passengers, who are =paying=
for and =expecting= a higher level of safety than people who are flying with a private pilot? You don't think that such commercial operations should be held to a higher standard? The person who gets on a commercial (say, air taxi) should have =only= the same degree of safety as the bloke who takes off in a private plane with his friend? 2: What is a "business operator"? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#73
Jose wrote:
1: Why should we not protect commercial passengers, who are =paying= for and =expecting= a higher level of safety than people who are flying with a private pilot? You don't think that such commercial operations should be held to a higher standard? The person who gets on a commercial (say, air taxi) should have =only= the same degree of safety as the bloke who takes off in a private plane with his friend? The commercial operator is bound by reported weather. It still wouldn't be the same level of safety; i.e. tin cans vs. Part 25 jet transports, professional crews and training vs. who knows what. 2: What is a "business operator"? NBAA type operator with turbine equipment professional flown. |
#74
On Sat, 02 Dec 2006 18:12:38 -0800, Sam Spade
wrote: Roy N5804F wrote: Roger, I forgot to mention, that like yourself I am licensed radio amateur [W8/G4DYR] and have the in-depth technical understanding of the avionics fitted in the Archer. If asked a similar question by the DE, I too would probably head off down the full electronic technical path to describe how it worked :-) Is that called "trick the man who holds your family jewels in his hands" before the flight portion of the check ride? Not at all. If you ask an engineer or some one familiar with how something works you are indeed likely for them to answer in the same manner as they always do when asked that question. They give the technical answer, after all he didn't ask me how I used the thing, he asked how it worked. I thought that was a bit deep for the instrument check ride, but I would not have though of answering the question in any other manner. My degree is in computer science, one of my minors is in math, I have 26 years working in instrumentation, and my hobbies are almost all technical. In the normal course of events it would never occur to me to tell some one how I use a piece of equipment when they ask how it works.:-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#75
: GA is not unique in this, and "hapless passengers" (or the equivalent in
: =any= activity) are =always= "just rolling the dice" to some degree. I : just believe that the amount of dice-rolling permitted in part 91 is : approprite. : : A few share your view that it is just right. There are a lot more who : think not-for-hire is overregulated and others who say it is underregulated. Not necessarily that everything is "just right," just that safety cannot be generated by excessive laws. If you take your example in the twin hitting the tank.... take away the fog and he could just as well have done the same thing in clear-and-a-million VFR. The Part-91 IFR minimum departure ops rule you desire wouldn't have stopped this joker from killing his "innocent passengers" in that case. So do we need a law that says, "Don't take off overloaded?" I'm pretty sure there already is one... A.R.(R.)O.W. People (pilots included) do stupid **** sometimes. Sometimes it's illegal, sometimes it's not. Sometimes they crash, sometimes they don't. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
#76
#77
Roger wrote:
after all he didn't ask me how I used the thing, he asked how it worked. You should have responded, "Very nicely". :-) |
#78
#79
Sam Spade writes:
Had it been good weather the tank would have stood out like a sore thumb. No one, except someone trying to commit suicide, would have flown into that tank with its lighting when it was visible. Oh yes, some people would. If they were stupid enough, they would. If this pilot knew about the tank and had been warned about it and actually knew how to fly, he would not fly into the tank, visibility or not. And if he were too stupid to do that, he'd fly right into it even in the clearest weather imaginable. It's not the he flew deliberately into a tank, it's that he was too dumb to know that he could not avoid hitting the tank. Being able to see the tank would not have helped in that case. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#80
You are making regulations based on the aircraft type? The pilot's certificate? I didn't see any of that in your reccomendation - you were making regulations based on usage (business usage, personal usage...) NBAA type operator "Basketball operator"? What is NBAA? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Accuracy of GPS in Garmin 430/530 | Will | Instrument Flight Rules | 110 | May 29th 06 04:58 PM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
