Ventus B - Fixed to Tilt Panel Conversion
Old December 24th 09, 05:20 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default Ventus B - Fixed to Tilt Panel Conversion
Anybody ever convert a fixed aluminum panel to a tilt version - using
the factory or any other design.
Question 2 ... can you replace the aluminum panel with a glass
version ... perhaps with the addition of tabs or stiffeners ...
thanks,
Old December 24th 09, 06:14 PM posted to rec.aviation.soaring
Richard[_9_]
On Dec 24, 8:20*am, "Ken Kochanski (KK)"
thanks,
Ken,
I converted my ventus b panel to fiberglass and moved it aft. Arms
too short..
I put a stiffener .25" X 2" aluminum bar with angle brackets about
12 inches forward of the original panel.
I have several fiber glass panels they are cut for the Craggy Aero
Ultimate. Pictures on the following page
http://www.craggyaero.com/ultimate.htm
Richard
www.craggyaero.com
Old December 24th 09, 06:17 PM posted to rec.aviation.soaring
Richard[_9_]
thanks,
Ken,
I also have a mold for a blank panel and could make you one.
Call if you are interested
Richard
www.craggyaero.com
Old December 24th 09, 06:52 PM posted to rec.aviation.soaring
JS
You can buy the tilt-up panel parts from Schempp-Hirth. Heinz would
know.
Perhaps there's a used one about somewhere, from a wrecked Ventus C or
later?
Liz Schwenkler did the mod on the Nimbus 3 I bought from her. Tilt-
up glass panel with tabs on it and notches cut in the canopy rail.
Also requires tabs on the glare shield. You may need a new glare
shield for the flat-topped panel, if your B has a round panel.
The S-H tilt up panels take a bit of getting used to. They make it
nicer to get in and out, except that you must use two steps to close
the canopy:
1. Tilt panel down.
2. Close canopy.
Skipping step 1 could break the forward hinge on the canopy. Rented a
Ventus C in South Africa which was combat repaired from the previous
pilot making that mistake.
Another note. Cut the brake handle down so it won't hit anything in
the panel. My radio was in the lowest spot, and when I bought the
glider the stick had to be moved out of the way to lower the panel
without hitting the dual concentric knobs. Cutting an inch or so off
the motorcycle brake handle fixed that.
You know the ridge will be working the day you rip the glider apart!
Old December 24th 09, 07:02 PM posted to rec.aviation.soaring
Richard[_9_]
On Dec 24, 9:52*am, JS wrote:
* You can buy the tilt-up panel parts from Schempp-Hirth. Heinz would
know.
later?
* Liz Schwenkler did the mod on the Nimbus 3 I bought from her. Tilt-
* The S-H tilt up panels take a bit of getting used to. They make it
the canopy:
1. Tilt panel down.
2. Close canopy.
* Another note. Cut the brake handle down so it won't hit anything in
* You know the ridge will be working the day you rip the glider apart!
Good idea cutting the brake handle.
Mine after the short arms mod could hit a radio knob if it was full
forward.
Richard
www.craggyaero.com
Old December 24th 09, 07:09 PM posted to rec.aviation.soaring
JS
Forgot it also needs tabs on the canopy rail to stop the panel from
jumping up on those red-line ridge days.
Old December 24th 09, 11:59 PM posted to rec.aviation.soaring
Dave Nadler
On Dec 24, 11:20*am, "Ken Kochanski (KK)"
thanks,
You should think about replacing the aluminum panel with a
glass part with a beefy flange. Much safer in an accident.
Proven unfortunately the hard way.
Hope that helps,
See ya Dave
Dave Nadler
Or just throw the handle away, doesn't do anything anyway...
Old December 25th 09, 12:32 AM posted to rec.aviation.soaring
JS
On Dec 24, 2:59*pm, Dave Nadler wrote:
( brake handle)
Good point!
The hydraulic brake mod helps.
Old December 25th 09, 02:03 AM posted to rec.aviation.soaring
Ken Kochanski (KK)
Hydraulic brake mod ?
Looking for an uncut Ventus panel?? Gary Emerson Soaring 3 October 15th 07 11:31 PM
Discus A Tilt-Up Panel Chuck Schroeder Soaring 1 February 18th 07 05:23 PM
Tilt-wing V-22 Osprey? Henry J Cobb Naval Aviation 0 February 11th 07 07:28 PM
Ventus Panel upgrade Fish Soaring 3 September 12th 06 11:44 PM
"V-22 Osprey Tilt-Rotor Aircraft" Mike Naval Aviation 0 September 28th 05 03:46 PM
