difference between SZD-48-1 and SZD 48
Old March 14th 10, 04:06 AM posted to rec.aviation.soaring
John Gruber
Default difference between SZD-48-1 and SZD 48
Any Jantar experts out there?
What the difference between an SZD-48-1 and SZD? I don't really know
that much about these aircraft. At the moment I'm trying to help
resolve an issue with play in the ailerons on a glider that is suppost
to be an SZD-48-1. One of the control rods has a lot of wear from the
rollers and needs to be replaced. The control rode from the SZD-48-1
parts catalog really doesn't match the one from the glider.
The Tech has an entry in 1978 stating the following:
convert to SZD-48-1 from SZD 48
On other thing I noticed is that this glider had side vents on the
fuse that I never noticed in the parts catalog. Did the factory make
mutant jantars??? Wondering if I need an SZD 48 catalog??
Any help would be appreciated. The serial number is w856.
Thanks
Old March 14th 10, 10:52 AM posted to rec.aviation.soaring
Dan[_4_]
What the difference between an SZD-48-1 and SZD? *I don't really know
that much about these aircraft. *At the moment I'm trying to help
to be an SZD-48-1. *One of the control rods has a lot of wear from the
rollers and needs to be replaced. *The control rode from the SZD-48-1
fuse that I never noticed in the parts catalog. *Did the factory make
mutant jantars??? *Wondering if I need an SZD 48 catalog??
Any help would be appreciated. *The serial number is w856.
Thanks
From Wikipedia: quote Production of the initial production version
the SZD-48 Jantar Standard followed the first flight piloted by Jan
Roman totalling 44. Soon superseded by the SZD-48-1 Jantar Standard 2
with small refinements including replacing the ventilation flaps with
a single flap on the underside in front of the launch hook. unquote
Sounds like you have an original SZD 48.
Factory SZD rep for North America is Windpath Corp; http://www.windpath.ca;
e-mail
Factory website is
http://www.szdjezow.com.pl/biul_jantarst_eng.html
(this is the Jantar 48 and 48-1 page). I note on the bulletins page
at http://www.szdjezow.com.pl/Biuletyny...td2_48_eng.pdf,
numbers 16 and 43, things on ailerons (in particular, 43 on bearing
wear which applies to your serial number). Bulletin 3 is the 48 to
48-1 change.
These should give you a good start.
I fly a 55.
Dan
Old March 14th 10, 12:32 PM posted to rec.aviation.soaring
GK[_2_]
SZD means Szybowcowe Zaklady Doswiadczalne in free translation:
Sailplane Experimental Factories - there was more than one.
48-1 is a glider model.
The early versions of 48 had vents placed under the wings, the later
version called 48-1 had a vent positioned up front, under the belly.
48-1 had a different water ballast tanks - I'd imagine control rod
would be different for that reason as well. It seem that you have an
early version of the 48. Please contact the North American dealer;
He's plenty of help.
The differences between the two we different water ballast tanks,
different extendable gear assembly and those vent holes.
Thanks
What the difference between the Aluckyguess Piloting 14 April 6th 07 03:25 AM
What is the difference between... expresstechonsite Home Built 7 June 5th 06 03:00 PM
what a difference! Chris Piloting 3 January 12th 06 11:52 PM
Another Canadian difference? Paul Tomblin Instrument Flight Rules 6 October 25th 05 04:04 PM
Difference between C150 and 152 DeltaDeltaDelta Piloting 23 March 26th 04 11:02 AM
