CG limits for Ventus 2bx?
Old March 28th 10, 02:16 AM posted to rec.aviation.soaring
Frank[_12_]
Default CG limits for Ventus 2bx?
I finally got some good main and tail wheel weights today for my V2bx
using the weighing procedure set out in my maintenance manual. I
computed the CG for both the empty and 'flying' configurations, but
was unable to compute the CG as a percentage of aft CG limit, as I
couldn't find anything in my documentation that unambiguously shows
the CG range and aft limit. There is a table on page 6.4.3 of my
manual that starts at 20.08in/510mm and ends at 27.56in/700mm, but its
not clear if these are the forward and aft limits or just convenient
graph endpoints.
Anyone care to tell me what I'm doing wrong here?
TIA,
Frank (TA)
Old March 28th 10, 01:52 PM posted to rec.aviation.soaring
Coucked
Frank,
I have a spread sheet I can send you that only requires you put your
moment arms in and your weights and will calculate the rest. Set up
for
and ASW-20.
Old March 28th 10, 03:31 PM posted to rec.aviation.soaring
Frank[_12_]
On Mar 28, 7:52*am, Coucked wrote:
Frank,
for
and ASW-20.
Dave,
Thanks, but this doesn't help for a V2bx unless I know the
corresponding forward/aft CG limits ;-).
Frank (TA)
Old March 28th 10, 08:49 PM posted to rec.aviation.soaring
mattm[_2_]
Frank,
for
and ASW-20.
Dave,
Frank (TA)
Frank,
what about the official data sheet at the faa website? My friend/AI
Roger
pulled that up when we did the w&b on my 19 last fall. Don't ask me
exactly
where it is since I searched fruitlessly to find that sheet again, but
I know
it's in there someplace!
-- Matt
Old March 28th 10, 08:57 PM posted to rec.aviation.soaring
jcarlyle
The FAA TCDS for the V2b is he
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/133e98b92a385fdb862570c80050abd1/$FILE/G04CE.pdf
and it does list the forward and aft CG range. I don't know how
different the "x" variant is from the 2b.
-John
Roger
exactly
I know
-- Matt
Old March 28th 10, 09:07 PM posted to rec.aviation.soaring
Whiskey Delta
Frank,
for
and ASW-20.
Dave,
Frank (TA)
If it's type certified, you might try looking here if you haven't
already: http://rgl.faa.gov/Regulatory_and_Gu...e?OpenFrameSet
They usually have all the cg limits, various stations (pilot, baggage,
water ballast, ballast, etc), etc listed in the document.
WD
Old March 28th 10, 09:09 PM posted to rec.aviation.soaring
Whiskey Delta
Frank,
for
and ASW-20.
Dave,
Frank (TA)
already: *http://rgl.faa.gov/Regulatory_and_Gu...keModel.nsf/Ma...
WD
oh, I see John beat me to it... sorry for the double post.
Old March 28th 10, 09:26 PM posted to rec.aviation.soaring
Frank[_12_]
Frank,
for
and ASW-20.
Dave,
Frank (TA)
WD
Thanks - that did it!
Frank (TA)
Old March 29th 10, 06:16 AM posted to rec.aviation.soaring
Bruce
Frank wrote:
On Mar 28, 7:52 am, Coucked wrote:
Frank,
for
and ASW-20.
Dave,
Frank (TA)
Those are obtained from the BGA datasheets - just go to the BGA
technical section.
Bruce
--- news://freenews.netfront.net/ - complaints: ---
Old March 30th 10, 04:13 PM posted to rec.aviation.soaring
Andy[_1_]
Frank (TA)
I don't see how it is possible, or legal, for the flight handbook of
any modern glider not to include the forward and aft CG limits.
Schleicher provides a graphical depiction of the complete mass and CG
envelope. As discussed here previously the limitations may not be as
simple as a single forward, and a single aft, limit.
When you received the additional information did it agree with what
was already published in the handbook?
Andy (GY)
blanik life limits, and new AD john Soaring 1 October 7th 07 01:55 AM
Crosswind rental limits? nrp Piloting 30 November 7th 06 01:26 PM
Canopy limits - How tall are you ??? Montblack Home Built 11 April 15th 06 04:50 PM
Canopy limits - How tall are you ??? Montblack Piloting 2 April 13th 06 05:41 AM
Insurance - smooth limits Paul kgyy Owning 22 May 13th 05 08:56 PM
