SSA State & Nat Records Rules Conflict
Old September 29th 10, 04:29 AM posted to rec.aviation.soaring
noel.wade
Default SSA State & Nat Records Rules Conflict
All -
OK so I've submitted some State Records and there is confusion amongst
the people processing the claims... Basically it boils down to a
question on how many Records can be claimed in a single flight.
Some people are saying that you can only submit 1 Distance and 1 Speed
record claimed per Category & Class, per flight. They are pointing to
this file: http://www.ssa.org/files/member/NatSTrules.pdf which is
shown as a link on the webpage whenever you view a table of State
Records. Looks like those records were effective starting in 2005?
HOWEVER, the "National & State Rules" PDF on the SSA website (http://
www.ssa.org/files/member/USN&StateRules2010.pdf) seems to permit
multiple simultaneous distance records (see section 6.3 and the
reference to 6.2).
The SSA "Summary of the Sporting Code" (http://www.ssa.org/files/
member/SCsummary09c.pdf) lists NO limitations on claims (see 1.4.1a I
think)
The SSA Badge & Record Guide () seems to indicate that you can have
multiple concurrent distance claims (1.4.5, 1.4.6, 1.4.8, and 1.4.7b
[Those last three documents are all on the "Forms" page, under the
"Soaring Achievement" area.]
And I'll say this: There ARE state records listed where a single
pilot's name shows up under multiple distance records on the same
date... And I have a hard time believing they all set them by flying
multiple times on a single day!
So, what's the correct answer - anyone know for sure?
--Noel
Old September 29th 10, 04:37 AM posted to rec.aviation.soaring
noel.wade
Whoops, forgot to add a link... The Badge & Record Guide is he
http://www.ssa.org/files/member/B&RGuide.pdf
Thanks!
--Noel
Old September 29th 10, 05:08 AM posted to rec.aviation.soaring
Darryl Ramm
On Sep 28, 8:37*pm, "noel.wade" wrote:
Whoops, forgot to add a link... *The Badge & Record Guide is hehttp://www.ssa.org/files/member/B&RGuide.pdf
Thanks!
--Noel
The rules are the rules. Have one of these people saying this is not
possible point to the exact rule forbidding this. SSA rules 6.2.c and
6.3.b specifically allow this. End of discussion.
Pretty hard to see how somebody who has actually read the rules could
interpret this in an other way.
Darryl
Old September 29th 10, 05:27 AM posted to rec.aviation.soaring
Frank Whiteley
On Sep 28, 9:29*pm, "noel.wade" wrote:
All -
the people processing the claims... *Basically it boils down to a
record claimed per Category & Class, per flight. *They are pointing to
this file: *http://www.ssa.org/files/member/NatSTrules.pdfwhich is
Records. *Looks like those records were effective starting in 2005?
HOWEVER, the "National & State Rules" PDF on the SSA website (http://www.ssa.org/files/member/USN&StateRules2010.pdf) seems to permit
reference to 6.2).
think)
And I'll say this: *There ARE state records listed where a single
date... *And I have a hard time believing they all set them by flying
--Noel
I've found at least one bad link that goes to the 2005 Rules and we'll
get that fixed. That may have resulted in some confusion earlier
today. The 2010 Rules should apply and appear to allow multiple
distance claims.
On the SSA Soaring Achievement page, the top of the RH column lists
the committee responsible for content. There's a show members link at
the bottom of the first section. When you follow that link, you can e-
mail any member, or the entire group.
Been trying to have someone in the know to hold a state record keeper
webinar for nearly two years per a request. Judy Ruprecht resigned
effective the end of June and applicants were being interviewed last I
heard.
Frank Whiteley
Old September 29th 10, 06:44 AM posted to rec.aviation.soaring
noel.wade
get that fixed. *That may have resulted in some confusion earlier
today. *The 2010 Rules should apply and appear to allow multiple
distance claims.
Thanks a bunch, Frank!
--Noel
Old September 29th 10, 12:39 PM posted to rec.aviation.soaring
Paul Remde
Hi Frank,
I'm sorry to hear that Judy Ruprecht has resigned. I like Judy. I look
forward to hearing who replaces her.
Best Regards,
Paul Remde
"Frank Whiteley" wrote in message
On Sep 28, 9:29 pm, "noel.wade" wrote:
All -
this file: http://www.ssa.org/files/member/NatSTrules.pdfwhich is
reference to 6.2).
think)
--Noel
distance claims.
heard.
Frank Whiteley
Old September 29th 10, 01:11 PM posted to rec.aviation.soaring
Tony[_5_]
On Sep 29, 6:39*am, "Paul Remde" wrote:
Hi Frank,
I'm sorry to hear that Judy Ruprecht has resigned. *I like Judy. *I look
Best Regards,
Paul Remde
All -
this file:http://www.ssa.org/files/member/NatSTrules.pdfwhichis
reference to 6.2).
think)
--Noel
distance claims.
the committee responsible for content. *There's a show members link at
the bottom of the first section. *When you follow that link, you can e-
webinar for nearly two years per a request. *Judy Ruprecht resigned
heard.
Frank Whiteley
yea there is one bad link to the 2005 rules. I found it this spring
when I was applying for some state records and it got me pretty good
and confused. I *think* that if you open up the state record matrix
from the SSA website and then click to go to the rules from that
window it goes to the 2005 rules.
Old September 29th 10, 06:01 PM posted to rec.aviation.soaring
Frank Whiteley
On Sep 29, 5:39*am, "Paul Remde" wrote:
Hi Frank,
Best Regards,
Paul Remde
All -
reference to 6.2).
think)
--Noel
distance claims.
heard.
Frank Whiteley
Bad link has been fixed.
Frank
Old September 29th 10, 06:07 PM posted to rec.aviation.soaring
jcarlyle
Frank, there may be something else wrong. Just for curiosity, on the
SSA web site under Home Soaring Achievement US & State Records I
checked Pennsylvania, General, and all 4 types sequentially (Distance,
Altitude, Out and Return Speed, Triangle Speed). Everything returned a
blank table, which I know can't be - Karl Striedieck, Tom Knauff and
Doris Grove, among others, have been very active in record setting in
PA!
-John
Frank
Old September 29th 10, 07:30 PM posted to rec.aviation.soaring
Tony[_5_]
PA!
-John
That doesnt mean that
A) They applied for the State Records
B) The State Record keeper put the records up on the website.
Stan Smith Delaware State Records (USA) Ken Kochanski (KK) Soaring 4 December 23rd 08 06:34 PM
US pilots-State Soaring Records since 1 October 2007 Frank Whiteley Soaring 0 July 31st 08 10:54 PM
State and National records question Gary Emerson Soaring 3 January 22nd 07 11:14 PM
OHIO state records? Keeper? [email protected] Soaring 3 May 4th 05 05:53 PM
State Record Question - Minimum Increase for Distance Records Gary Emerson Soaring 3 November 11th 03 04:18 PM
