Using Wideband Aviation Antenna for TV Reception?
Old July 6th 04, 10:03 PM
CHANGE USERNAME TO westes
Default Using Wideband Aviation Antenna for TV Reception?
Will a wideband aviation antenna, that receives across 50 MHz up to over
1000 Mhz, be useful for VHF and UHF TV reception as well as aviation
frequency reception?
Can such an antenna be used by multiple devices listening to different
frequencies at the same time?
Will
westes AT earthbroadcast.com
Old July 7th 04, 01:32 AM
On Tue, 6 Jul 2004 13:03:36 -0700, "CHANGE USERNAME TO westes"
Theoretically yes.
In practice these broadband antennas have poor gain (0db) as it's a
compromise. Unless your signals on VHF and UHF are strong the result
will be poor.
If you split one antenna between two receivers then each will receive
only half the signal (-3db). In fact less due to splitter losses. The
only way to overcome this is to use a broadband amplifier (covering
VHF & UHF) and ideally close to the antenna to avoid cable losses.
This will boost the signal first so it can then be split.
A somewhat technical reply is:
A very rough guide to antenna performance is double the antenna
elements gives double the signal. A broadband antenna is likely to be
slightly poorer than a simple dipole. Using a dipole as a reference
you will get roughtly double (3db) more signal with two elements and
roughly double again (6db) with four elements. If you double yet again
to eight elements that's another 3db. Each element needs to be the
correct length for each band of frequencies.
If by chance the UHF frequencies are exactly three time the VHF
frequency then one antenna could be used but performance would not be
as good s two separate antennas.
David
E-mail (Remove Space after pilot): pilot
Antenna questions Steve Ruse Home Built 10 January 27th 05 03:30 AM
LORAN antenna difference? JFLEISC Home Built 6 December 24th 04 11:10 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 06:34 PM
