Antenna informtion needed
Old April 11th 04, 01:01 AM
dave
Default Antenna informtion needed
I have a bent whip antenna that I'm about to mount in a friends Lancair
and I'm wondering if I should see any connectivity between the center
conductor of the BNC connector to the stainless steel element?
The ohmmeter shows nothing.
Is this thing have capacitance coupling?
Thanks
Dave
Old April 11th 04, 01:19 AM
Jim Weir
If you are talking about one of those old 3/16" stainless steel whips, yes you
do need a connection between the center pin of the RF connector and the element.
You also need a ground plane directly at the base of that antenna if you are
mounting the antenna in a plastic location.
If you plan on using that antenna with a good radio, do yourself a favor and
save your friend a lot of grief by using the antenna as a doorstop. The VSWR at
the band edges with that sucker is something to behold. Remember, that antenna
was designed back in the days when 90 channels (118-127 on 0.1 MHz. spacing) was
just about airline quality.
dave
-I have a bent whip antenna that I'm about to mount in a friends Lancair
-and I'm wondering if I should see any connectivity between the center
-conductor of the BNC connector to the stainless steel element?
-The ohmmeter shows nothing.
-Is this thing have capacitance coupling?
-Thanks
-Dave
http://www.rst-engr.com
Old April 11th 04, 02:10 AM
dave
Hey Jim Thanks!
Maybe I should just build him a generic dipole out of wire or copper tape.
How do you get the bandwidth wider, use a wider conductor?
Also, my only vswr meter is a old radioshack one for use in the 10 meter
range, can I retrofit it to work in the 120 mhz area?
Thanks as always
Dave
dave
-Thanks
-Dave
Old April 11th 04, 02:21 AM
Vaughn
"dave" wrote in message
news:%10ec.6115$_K3.46405@attbi_s53...
Hey Jim Thanks!
It depends, some of those CB vswr meters were pure junk, and some are
OK for the VHF range. The best way to tell is to check it on a couple of
known good installations and also against a dummy load if you have access to
one. If the meter reads in watts, ignore that part; the power will read
high at higher frequencies.
Vaughn
Old April 11th 04, 02:53 AM
Don Tuite
On Sat, 10 Apr 2004 16:19:25 -0700, Jim Weir wrote:
The VSWR at
Respectful, question, Jim: If he has a transistor output stage. . . .
(etc. etc.)
Don
Old April 11th 04, 03:14 AM
Jim Weir
dave
-Hey Jim Thanks!
-Maybe I should just build him a generic dipole out of wire or copper tape.
-How do you get the bandwidth wider, use a wider conductor?
That is correct. The "fatter" the conductor the wider the bandwidth. You can
do a pretty fair job with two or three strands of bare copper wire (stripped
romex) in parallel for each arm of the dipole. The problem is that the fatter
the wire (or the apparent wire) the shorter will be the elements. I know that
½" copper tape centers up pretty nice with a length around 20½". If you use
bare copper, you might cut one of them a half inch longer and one of them half
an inch shorter and see what happens.
-Also, my only vswr meter is a old radioshack one for use in the 10 meter
- range, can I retrofit it to work in the 120 mhz area?
9 out of 10 of those old CB VSWR meters aren't worth a darn in the aircraft
band. It is catchascatchcan as to whether yours is going to be "good" or not.
One easy way to tell is to calibrate it with a few known good antenna
installations and see if the CB meter comes even CLOSE to a known good meter.
Old April 11th 04, 03:18 AM
Jim Weir
Double whammy with a solidstate output stage. Back in the old vacuum tube days
we just said to hell with the reflective loss, let the RF output tube handle it.
So the plate glowed cherry red for a few seconds, no big deal.
Solid state "plates" don't glow cherry red but for a microsecond or so and that
snap you just heard was $100 worth of frenchfried silicon. So we got clever in
our old age and built in "VSWR Protection Circuits", which do nothing more than
reduce the available power in the transmitter output to something the
transistors can handle. You reduce the transmitted power by reflection and then
reduce it even further by the protection circuit.
Ain't no winnin' with a narrowband antenna and a 760 channel radio.
Don Tuite
-Respectful, question, Jim: If he has a transistor output stage. . . .
-(etc. etc.)
-Don
Old April 11th 04, 03:45 AM
dave
Ok that brings an interesting thought,
When building a multiband antenna, multiple elements can be attached to
the same feed point and the element cut closest to the resonant freq
will radiate.
I did this with an old HF radio for 20, 40 and 80M.
Is that what you're doing with the three strands of wire?
One say 19.5, the next 20 and the longest at 20.5 inches?
One should be resonant somewhere in the band?
Also, I read that should I use a torid (SP) and put a loop of coax to
keep reflections down.
Sound good?
If I don't have a vswr meter around should I be pretty safe using this
configuration?
Thanks for the help!
Dave
Jim Weir wrote:
dave
-Hey Jim Thanks!
Old April 11th 04, 04:50 AM
Jim Weir
dave
-Ok that brings an interesting thought,
-When building a multiband antenna, multiple elements can be attached to
-the same feed point and the element cut closest to the resonant freq
-will radiate.
-I did this with an old HF radio for 20, 40 and 80M.
Yes, but you will clearly note that you did not run the elements very close
together, or you might just as well have used a single piece of wire. The
elements were separated, and the more separation the better the multiband
antenna worked.
However, here you are working with a single frequency, and if the wires are
spaced roughly a wire diameter apart, the apparent bandwidth is outrageously
good.
-Also, I read that should I use a torid (SP) and put a loop of coax to
-keep reflections down.
Most folks that use toroids as baluns (actually as chokes) use a toroid that
just slips over the coax and a couple-three of them close to the antenna. This
makes a single-turn coil for each toroid. If you've got the room to use a large
toroid and several loops through it, go for it. Embedding them in the structure
doesn't allow me to do my designs like that {;-)
Don't forget -- the toroid material must be "good" at the frequency of interest,
or all you've done is put a steel nut around the coax, and not a choke.
Old April 11th 04, 04:53 AM
KJ
HI Dave- This is a quarter wave whip- must be mounted on metal- shield
to ground and center conductor to whip- the whip is not at ground
potential-
Good luck, KJ
dave wrote in message news:n1%dc.5551$_K3.46068@attbi_s53...
Thanks
Dave
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
Antenna informtion needed dave Home Built 14 April 12th 04 06:05 AM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 06:34 PM
