Wing walk anti-slip
Old May 1st 04, 12:18 AM
Jerry Jesion
Default Wing walk anti-slip
My plane has the self stick wing walk anti-skid material and I wish to
remove it and apply Randolf's version. Any suggestions on how to
remove the self stick stuff??
Jerry
Old May 1st 04, 01:37 AM
Stu Gotts
Peel very slowly and carefully. You may want to start heating it A
LITTLE BIT with a hair dryer. After that, use MEK to clean the glue
residue, prep and paint away.
On Fri, 30 Apr 2004 18:18:25 -0400, Jerry Jesion
Jerry
Old May 1st 04, 04:39 AM
Kyle Boatright
Mineral spirits is an excellent solvent for adhesives, but won't harm paint.
It is also great for removing tar and bugs from your car (or airplane for
that matter).
A little heat, a little mineral spirits, and those wing walks will come
right off. Too much heat and a little mineral spirits, and you may have a
problem...
"Jerry Jesion" wrote in message
Jerry
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
Randolph Wing Walk Compound Larryskydives Owning 7 March 7th 04 10:44 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
