FLARM Installation
Old March 16th 12, 09:58 PM posted to rec.aviation.soaring
Boise Pilot
Default FLARM Installation
Now that the portable FLARM is out, those of you who have mounted it,
would you mind informing - photos would be great too - how you did
it. Looking for a good solution before I mess things up too much.
Tom
Idaho
Old March 16th 12, 10:15 PM posted to rec.aviation.soaring
Renny[_2_]
it. *Looking for a good solution before I mess things up too much.
Tom
Idaho
Tom,
Mark Mocho has made some very nice portable PF mounts for pilots at
Moriarty. His contact info is on his website at:
http://mmfabrication.com/
Thanks - Renny
Old March 17th 12, 07:19 AM posted to rec.aviation.soaring
bumper[_4_]
On the Schleicher ASH-26E, there isn't enough room above the
glareshield to allow clearance for the PowerFlarm antenna - - it's not
supposed to contact the canopy. This, and to avoid it blocking the
view or panel, required making a shelf bracket to extend aft from the
glareshield lip and also to allow the PF to mount a bit lower. This
has the added advantage of bringing the control knob a bit closer to
the pilot for easy access.
I made the bracket from aluminum with a curved portion to mate with
the underside of the glareshield, TIG welded to the bracket shelf. The
curved underside mount could be made of wood and the shelf screwed to
that if TIG welding isn't available. Links to pictures:
http://i674.photobucket.com/albums/v...021800x451.jpg
http://i674.photobucket.com/albums/v...023800x451.jpg
http://i674.photobucket.com/albums/v...024451x800.jpg
bumper
Old March 17th 12, 11:15 AM posted to rec.aviation.soaring
PMSC Member
bumper
That bracket looks a little...uh... "undesirable" in the event of a
bail out. My $0.02.
T8
Old March 17th 12, 03:14 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
bumper
bail out. *My $0.02.
T8- Hide quoted text -
- Show quoted text -
I mounted my FLARM on top of my fixed panel using 2" Velcro and
powered it with ships power. I also tried to use the FLARM GPS signal
to drive my SN-10 with no success. The manual states MNEA-0183 version
2.0 compatible GPGGA and GPRMC info at a configured data rate.
My question; Is this sentence compatable with the SN-10? I'm sure my
pin-out was correct.
JJ
Old March 17th 12, 03:30 PM posted to rec.aviation.soaring
bumper[_4_]
bumper
T8
The bracket (and PowerFlarm) "goes away" with the canopy in the 26E,
so there is a break-away plug under the glareshield so the canopy
eject process won't be impeded should I decide not to try landing the
remaining glider bits.
The bracket is .050" aluminum, and even if used on a glider such as
the DG-800 series, where the pedestal stays put, would easily bend out
of the way. Is could, if need be, be mounted with frangible nylon
screws or 3-M mushroom style interlocking tape.
bumper
Old March 17th 12, 06:09 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
bumper
T8
This is exactly my concern. When you blow the canopy, I'm told it
often comes straight back, in which case you could (perhaps) catch the
flarm and the bracket in the head.
As well, thin bits of aluminum in the cockpit have inflicted some
nasty injuries in crash landings. I'd be disinclined to put something
like this in my cockpit.
T8
Old March 17th 12, 06:30 PM posted to rec.aviation.soaring
Paul Remde
"JJ Sinclair" wrote in message
bumper
bail out. My $0.02.
JJ
___
Hi JJ,
Yes. The data sentences you mention above are all the SN10 needs. However,
be sure that you match the baud rates. The FLARM defaults to 19200 baud and
the SN10 defaults to 4800 baud. If you have somewhat recent software in
your SN10 you can set the baud rate to 19200.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old March 18th 12, 02:42 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
The canopy on the ASH 26 E has a "Roeger hook" at the rear. When
jettisoned, the canopy pivots around the back edge and blows free over
the top of the glider. Ditto for the ASW 27 and many other gliders. If
you have a forward opening canopy and you don't have a "hook", your
manufacturer may have retrofit kit for your glider, and you should
consider installing it.
The "thin bits" in bumper's glider are an arm's length from his face,
and if they get to his face, he has far more serious problems, I think.
In any case, bending a smooth, rounded edge on it would be easy.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old March 18th 12, 06:09 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
*The FLARM defaults to 19200 baud and
the SN10 defaults to 4800 baud. *If you have somewhat recent software in
That did it! So,if you want to drive the SN-10 with FLARM GPS, you
need to select 19200 baud on the NMEA (SN-10 page about 3 from the end
in setup mode). Now, I can leave the Garmin GPS off and only use it if
the FLARM GPS fails, saving about 100 m/a. I still have 2 GPS's and 2
flight recorders working all the time.
Thanks Paul
I read the amps as I turned on all equipment and got the following.
Dittle radio---.09
Alt encoder----.25
Becker Tnspdr--.2
Model 20 GPS---.11
FLARM (tracking).1
SN-10----------.17
B-400----------.1
With all the above on, GPS tracking and FLARM showing a target, I read
1.02 amps total. When I transmitted on the radio---------2.3 total
amps.
Cheers,
JJ
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 06:53 PM
FLARM Robert Hart Soaring 50 March 16th 06 11:20 PM
Flarm Mal Soaring 4 October 19th 05 08:44 AM
FLARM John Galloway Soaring 9 November 27th 04 07:16 AM
